smosse Posted February 11, 2007 Posted February 11, 2007 (edited) Hello All ! i live in a residential appartment. We have shared dish to astra and hotbird for everybody. they have a limited amount of frequencys..so then dont relay all the channels. And the BIG problem is that all transponder from astra and hotbird are stream back to only one virtual 'sat' so i cannot use official sat conf i know one thing from the installer. for exemple from Astra 19.2 East If there is channel at 11739 , it will go in there system at 1139 ( 11739 - 10600 ) then , they will bring it to my place at another frequency 1290. but i dont really understand all this, as im a big newbie in Satellite. -Can do a sort of blind scan , so i can scan everything ? -do i need to creat my own virtual satellite conf file ? im not sure if i made myself clear Thanks for you help. Edited February 11, 2007 by smosse Quote
smosse Posted February 17, 2007 Author Posted February 17, 2007 Hello all ! i live in an area where they use transposed frequency to bring satellite to our appartment because we cannot have our own dish To find channels i found that scanning frequencys from astra and hotbird list in DVBViewer brings me almsot all the channels. BUT , i have i lot in dupe and more ! i can have 8 times the same channel ! is there a way , a script that can scan in my channel list, and mark as bad, all that channel wich cannot be rendered. Or only keep those with a signal enough strong to view it.. Quote
Griga Posted February 17, 2007 Posted February 17, 2007 Get TransEdit from the members area (and the manual!). It provides more scanning facilities than DVBViewer. Quote
Derrick Posted February 17, 2007 Posted February 17, 2007 i can have 8 times the same channel ! The truth will be somewhere in the center of the frequency range that yields a lock. Because there is no feedback from the tuner, ist is impossible to find out the exact carrier frequency. If you knew the setup of the frequency translating equipment you could built your personal tranponder.ini. Quote
hdv Posted February 17, 2007 Posted February 17, 2007 Hello, a classic example of crossposting, Blind Scan help, started by smosse Quote
Griga Posted February 17, 2007 Posted February 17, 2007 Merged. Crossposting is unwanted in this forum. Quote
smosse Posted February 18, 2007 Author Posted February 18, 2007 Merged. Crossposting is unwanted in this forum. actually it was NOT crosspost.. it was 2 separate questions.. but thanks for the answers anyway Quote
smosse Posted February 18, 2007 Author Posted February 18, 2007 (edited) If you knew the setup of the frequency translating equipment you could built your personal tranponder.ini. Actually i got some infos from the installer.a list with the real freq , and then the streamed. Here an exemple for Astra Real Transponder adress 11739 then i got 2 values FI1 is 1139 ( i realise it is 11739 - 10600) and another value FI2 is 1290 (11739 - 10449) next transponder exemple Real Transponder adress 12402 then i got 2 values FI1 is 1802 ( it is 12402 - 10600) and the value FI2 is 1290 (12402 - 10432) first value is always with minus 10600 , but second values varies.. does this help ? Edited February 18, 2007 by smosse Quote
smosse Posted February 18, 2007 Author Posted February 18, 2007 ok i found ! So when 11739 is real Freq of tranponder and FI 1 is 1139 i then do 11739-1139 = 10600 Then i just add this result to the second value FI 2 : 1290 + 10600 = 11890 So my transposed Freq is 11890 ! I have create my own transponder list with transedit.. Thank you ! Quote
smosse Posted February 18, 2007 Author Posted February 18, 2007 NOw another question .. as it is transposed frequency , i have both chanel from Astra and Hotbird, and so some of the channel are in dupe.. for Exemple i will have TF1 from TPS provider and CANALSAT I have a Canaplus/CanalSat subscription so i can only decrypt this one. Is there a way to remove from the channel list all the channel that i cannot decrypt ? The provider is not recognice correctly for all channel , so i cannot use this way. Perhaps also a way to sort channel by signal strengh ? I dont know when i dont see a channel, if it is because the signal is not strong enough, or it is because i dont have the right subscription. thx ! Quote
bergh Posted February 20, 2007 Posted February 20, 2007 (edited) Hello ! 1.) Go to Channel list click on Channel and press the DEL Button, channel should be deleted(may be with a question : Do you really want to hurt me ....) 2.) Well Signal Strenth is normally shown in the "Status Bar " of the DVBViewer. If not click on it several times until you see the signal strenght. It is also show on encrypted Channels that DVBViewer can not decode, so you can see the strenght and a Picture = O.K. Or a strenght and no picture = Delete. I am pretty sure that the signal strenght is explained in the Manual /readMe Edited February 20, 2007 by bergh Quote
