Chiefcooker Posted February 20, 2007 Posted February 20, 2007 hy everyone, i`ve used now the pinnacle 400e usb2 box with DVBViewer, it it always works flawless. first i want to thank all devs for this nice software. so, now i've cable tv, so i have to sell my pinnacle and i want to buy a card for cable tv now, which works perfect with DVBViewer and my pc. (or notebook) if its possible i want to buy a extern usb2 card again. (because of the notebook) please help me, thx my sys: athlon xp 2400+ with 2200MHz 1GB Ram (333) xfx nvidia 7600GTX ###### my notebook: mobile p4 3,06GHz with hypertreading 1GB Ram (333 i think) ati radeon mobility 9000 the pinnacle card worked very well with my devices. regards, chief Quote
villi Posted February 21, 2007 Posted February 21, 2007 (edited) so, now i've cable tv, so i have to sell my pinnacle and i want to buy a card for cable tv now, which works perfect with DVBViewer and my pc. (or notebook)if its possible i want to buy a extern usb2 card again. (because of the notebook) Hello, I have buy me after x-number of cards a Digital Everewhere FireDTV. You can use with with both your notebook and your desktop-pc. You only need a firewire connection. The best I ever had, very most expansive, but make not my mistake: save the money and buy and test again and again. FireDTV/Floppy DTV is the best for all DVB C/S... I think. For the DVBViewer PRO too. Edited February 21, 2007 by villi Quote
Chiefcooker Posted February 21, 2007 Author Posted February 21, 2007 hy, thx for answering. this card costs about 180€, is no cheaper possibility out there? Quote
villi Posted February 21, 2007 Posted February 21, 2007 (edited) Yes, but.... I has the TWINHAN CAB-CI this card cost here 130 Euro. It works good, but has some problems with ACPI-Mode S 3 - I have blue screen on restart, not ever, but sometimes. Other cards with CI? Try Technotrend Products... Some users have problems with this too, I has a Technotrend DVB-C Card with CI and has some trouble with PID-Errors and PTS-Errors. Visual Stutter I hope you understand. And ProjectX give me the PTS and PID-Errors and there are many of this errors. I would say digital-cable is not easy to find products, then you want a good hardware, it is very hard to find this. And the hardware is good, but when the driver is bad. But when you buy a FLOPPYDTV or FireDTV you have no trouble from the begin. I know, they are much expensive! It was not easy for me to buy it for so much money, but I buy other cards and have trouble... When I has buy me the FireDTV first a has save all the money... I only can say "Test cheaper products, when you have luck they runs without any problems" but when they run not so you want - then you have the same as I... You buy and test, and buy and test... And at the end you buy a DigitalEverywhere... thats my working with Digital-Cable. Edited February 21, 2007 by villi Quote
