Windows Xp Pro Or Windows Xp Home?
Delphi
I am considering ordering a PC for use in my home network, acting as a client.
It will have its own tuner.
I have another powerfull PC acting as server ( XP Pro) with 2 tuners.
I don't use windows server, so so computer will be part of a domaine.
So my question is:
Is there any reason to buy Windows XP Pro or will Windows XP Home do?
Thanks in advance
Edited by Delphi
Imho home will do. If you want to use remote desktop, only the server needs xp_pro.
BTW, with Windows XP Home you can't open more than 1 LAN resource at a time...
:dvbviewer:
Thanks for the answers. I will buy XP home :bounce: .
What does a "LAN resource" mean exactly ? Example ?
Edited by dgdg
Typical LAN resources are shared folders and shared printers; rarely used LAN resources are shared fax, shared scanners, shared CD-jukebox and so on...
:bounce:
I have just changed my order from XP home to XP Pro.
Don't want to risk any problems for a relatively small saving.
Anyway, it would be interesting to have answers to the following:
1) Is an internet download a LAN resource?
2) If yes, I will then have problems with XP Home when watching a streamed TV recording (in a shared folder) while downloading say EPG (I use myXMLTV), right?
Thanks in advance
Edited by Delphi
Internet should be considered a WAN resource, not a LAN one...
Also join a stream in the LAN IMHO can't be considered a LAN connection to a resource (see the list of LAN resources), but I don't know so in deep how XP Home consider this and behave... I'm sorry for that...
Maybe a XP Home owner can be more precise with this subj...
:bounce:
