dbercot Posted March 31, 2007 Share Posted March 31, 2007 Hi, I'd like to use Haali renderer with DVBViewer. So, I've installed MatroskaSplitter_[2007_03_28].exe which seems to have everything... After a reboot, nothing seems to have changed : in DVBViewer, I have only overlay and VMR7 & 9. Am I wrong somewhere ? Thank you very much. David. Quote Link to comment
CiNcH Posted March 31, 2007 Share Posted March 31, 2007 No, you are not. Haali Renderer is simply not supported. Quote Link to comment
dbercot Posted March 31, 2007 Author Share Posted March 31, 2007 No, you are not. Haali Renderer is simply not supported. OK. Never mind. Will it be in another build ? Thank you. David. Quote Link to comment
CiNcH Posted March 31, 2007 Share Posted March 31, 2007 Christian is currently working on his own renderer as well which will be pretty similar to Haali's renderer, also using Direct3D and pixelshaders. Plus it will have a decent OSD mixing engine... See beta test of D3D Renderengine Quote Link to comment
dbercot Posted April 2, 2007 Author Share Posted April 2, 2007 Christian is currently working on his own renderer as well which will be pretty similar to Haali's renderer, also using Direct3D and pixelshaders. Plus it will have a decent OSD mixing engine... See beta test of D3D Renderengine OK. Great ! Thank you. David. Quote Link to comment
