actpower Posted April 8, 2007 Posted April 8, 2007 Hi!. I recently purchased DVBViewer, and the first look are fantastic, good work with it!. Unfortunally, strange errors appears. From the first tests that I done, DVBViewer stop (hangs). This force to me to manually stop the program, and execute again. These stops are totally random. May appear seconds after execute, or whe switch to another channel, or several minutes, o not. But usually, the hang appears. A thing that surprise me, is that I have recording a program and the hangs appear, the record continues!!!. So, I can think that maybe a problem of display the screen or something else. My computer it´s powerfull (Dual Opteron Dual Core, 4GB RAM, Geforce 7900) so these cannot be the problems in a first look. Can any help me?. Maybe the drivers can do something?. I´m running DVBViewer under Windows XP x64 version. Greetings! Quote
Oliver Posted April 8, 2007 Posted April 8, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
actpower Posted April 8, 2007 Author Posted April 8, 2007 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Here is attached! ¿need more?. Thanks! support.zip Quote
Gioxy Posted April 10, 2007 Posted April 10, 2007 (edited) Mmh, your support.zip is rather incomplete, so it's impossible to understand what's happen with your installation... Try to rebuild the supporttool's file (it must contain at least a dozen of files) and repost it... Edited April 10, 2007 by Gioxy Quote
Lars_MQ Posted April 10, 2007 Posted April 10, 2007 Please post a correct support.zip and nothing you made up. Quote
actpower Posted April 10, 2007 Author Posted April 10, 2007 Well, there is again the support.zip file. support.zip Quote
Gioxy Posted April 10, 2007 Posted April 10, 2007 ...again an incomplete support.zip : DVBViewer.log is missing... but: From Systeminfo.txt:Elecard MPEG-2 Video Decoder: 00800001 (File is missing) Elecard Layer II Audio Decoder: 50000000 (File is missing) From setup.xml: <section name="MPEG"> <entry name="Videocodec">Moonlight-Elecard MPEG2 Video Decoder</entry> ...as you can see, your PC have a DirectX problem (so not a DVBViewer one)... Try to: • set "MainConcept MPEG Video Decoder" as MPEG Video Decoder or • reinstall Elecard codecs or • uninstall *and* unregister all Elecard codecs (regsvr32 /u [codec_file_name]) Other *possible* problematic issues can be: • Nero codecs installed • SB Audigy 4 drivers • Windows XP x64 version After the main problem is solved, to try to get the best you can also try to: • reapply *last* "DirectX 9.0c Redist" for your language • set "Default DirectSound Device" as "Audio Renderer" • unset "Detect Video" & "Detect Audio" • set "Use Audiofilter for visual and Equalizer..." Quote
actpower Posted April 10, 2007 Author Posted April 10, 2007 I´m very sorry, but I executed the program and wait to see the support.zip file. I have search for the file, and I attach here. I´m try to adjust the setting as suggested. Thanks again!!! DVBViewer.log Quote
actpower Posted April 10, 2007 Author Posted April 10, 2007 Well...I change that you say, and for now works perfectly :-). The only problem it´s that I cannot modify the settings for the MPEG2 decoder (currently Mainconcept). I access to the window of the decoder but it´s inactive. What MPEG2 decoder it´s the better in your opinion? Another Question: I try to save a .ts stream with caption data (Subtitles), but VLC and Media Player Classic cannot "see" it. I try to play the .ts with DVBViewer and play very fast ( :-?) and no subtitle data it´s recorded (!!) Thanks for all!!! Quote
Gioxy Posted April 11, 2007 Posted April 11, 2007 I cannot modify the settings for the MPEG2 decoderEvery codec is different... maybe you can add/change some setting in the windows registry, but is up to you to find how... What MPEG2 decoder it´s the better in your opinion?It's depending on many things, there is always a struggle upon this matter... Actually the best for you graphic card seems to be the one that came with PowerDVD7 and NVidia PureVideo... Another Question: I try to save a .ts stream with caption data (Subtitles)...Search on this forum, there are various tread about this subject... Quote
actpower Posted April 11, 2007 Author Posted April 11, 2007 Every codec is different... maybe you can add/change some setting in the windows registry, but is up to you to find how... It's depending on many things, there is always a struggle upon this matter... Actually the best for you graphic card seems to be the one that came with PowerDVD7 and NVidia PureVideo... Search on this forum, there are various tread about this subject... Nvidia Purevideo it´s not free, it´s true?. At last, it´s what I read in the nvidia website... About the settings of the Mainconcept codec, I can access to it trought Media Player classic and even Graphedit, but in DVBViewer apperars grey the part of the deinterlacing :-?. Quote
Gioxy Posted April 12, 2007 Posted April 12, 2007 Nvidia Purevideo it´s not free, it´s true?. No, and also PowerDVD isn't free... but you ask me for the best MPEG decoder... (however they aren't too much expensive...) I can access to it trought Media Player classic and even Graphedit, but in DVBViewer apperars grey the part of the deinterlacing :-?. "Normally" any setting you make to a codec config within a prog is stored in the registry and mantained for other prog, but it isn't always true... anyway I haven't Mainconcept codec, so I'm sorry but I can't know... Quote
