Probleme With Tsplayer For"ts"
rozebud!
hi everybody ;) ,
i'have got a problem when i try convert a video "ts" in "mpg" i don't can read video who are converted whith other player :bye:
i want convert in mpg because when i compresse a "ts" in "avi" with virutal dub mod got a problem's sound/video :(
if you test convert you can found a video -> HERE
thank you ;)
..only possible for mpeg2. Your TS is H.264.
sry but I dont understand your question at all...? do you want to convert from .ts into .mpg cause an .avi container gives you out-of-sync problems or what?
would you prefer .avi instead of .mpg?
ok tanks ;)
i want convert my"ts" in "mpg" because with a "mpg" i can correct the problem synchro audio/video with "videoredo",
and after when i have correct the synchro i can use virtual dub mod for make a "avi"
The TSPlayer supports re-packaging TS with H.264 content as MPEG2 program stream (MPG).
However, that's no real conversion. TSPlayer just puts the data from the transport stream into a program stream container, which is quite unusual for H.264 and only supported by the Elecard software (e.g. XMuxer Pro), as far as I know.
I don't know if re-packaging is what you want... unfortunately I can't test the uploaded file, because it's too big and the download data rate far too low.
Hello,
i had downloaded your file too, (with Flashget or NetTransport its run fast).
But with a MPEG program stream container you cant use it in VideoReDo, because VideoReDo can't handle H.254 encoded video!
So you will need an other video editing tool.
what you need the .avi for? do you want to playback your file on a standalone-DVD player?
i know it's for this i want convert "ts" in "mpeg" for use in video in videoredo for correct the synchro audio/video
i can open the video with in virtual dub mod by avisynth,but when when i convert in "avi" i have a biiiiiiggg probleme of synchro audio/video ;)
it's for this when i have see the tools "tsplayer" ,i become happy ,i believe this tools can make this ;)
thanks,but i'm not verry in english,in german i don't know read german :bye: (i'm french)
no i want convert for use in virtual dub mod cut scene and compress in avi.for this it's ok but the problem is when read the
"avi" i have many probleme of synchro
