Pinnacle Remote
extremeno
Just for interested people. Here's my profiles.ini section for Pinnacle remote type 2 to work with DVBViewer. You must complement it with a few keyboard definitions in input options. All keys do what they are supposed to.
[DVBViewer]
key1017=KEYBOARD UP+^UP
key1081=KEYBOARD UP+^UP
key1018=KEYBOARD DOWN+^DOWN
key1082=KEYBOARD DOWN+^DOWN
key1020=KEYBOARD RIGHT+^RIGHT
key1084=KEYBOARD RIGHT+^RIGHT
key1019=KEYBOARD LEFT+^LEFT
key1083=KEYBOARD LEFT+^LEFT
key1021=KEYBOARD ENTER+^ENTER
key1013=KEYBOARD ESC+^ESC
key1002=KEYBOARD ALT+F3+^ALT+^F3
key1001=KEYBOARD m+^m
key1008=KEYBOARD x+^x
key1045=KEYBOARD w+^w
key1012=KEYBOARD F8+^F8
key1038=KEYBOARD b+^b
key1047=KEYBOARD t+^t
key1022=KEYBOARD 1+^1
key1023=KEYBOARD 2+^2
key1024=KEYBOARD 3+^3
key1025=KEYBOARD 4+^4
key1026=KEYBOARD 5+^5
key1027=KEYBOARD 6+^6
key1028=KEYBOARD 7+^7
key1029=KEYBOARD 8+^8
key1030=KEYBOARD 9+^9
key1032=KEYBOARD 0+^0
key1033=KEYBOARD F2+^F2
;key1010=KEYBOARD F1+^F1
key1046=KEYBOARD r+^r
key1028=KEYBOARD a+^a
key1044=KEYBOARD PGDN+^PGDN
key1043=KEYBOARD PGUP+^PGUP
key1034=KEYBOARD F6+^F6
key1036=KEYBOARD F7+^F7
key1039=KEYBOARD F10+^F10
key1037=KEYBOARD F9+^F9
key1035=KEYBOARD SPACE+SPACE
key1016=KEYBOARD NUMSUB+^NUMSUB
key1015=KEYBOARD NUMADD+^NUMADD
key1011=KEYBOARD F7+^F7
key1010=KEYBOARD F6+^F6
key1009=KEYBOARD F5+^F5
key1031=KEYBOARD F4+^F4
key1040=KEYBOARD l+^l
key1042=KEYBOARD g+^g
key1041=KEYBOARD q+^q
key1006=KEYBOARD h+^h
  • Like 1
  • 3 weeks later...
Nice post! I did not know that it was possible.
As an addition to the above information I would like to provide Pinnacle's remote application supporting their serial port infrared receiver and infrared receivers built into DVB-T USB sticks. It features the mapping of infrared codes of keypresses to keyboard shortcuts.
Included is the profiles.ini supporting basic functionality for the Pinnacle remote type C (the little black one):
[DVBViewer]
; Remote Type C
; mute
key60=KEYBOARD m+^m
; numeric key 1
key49=KEYBOARD 1+^1
; numeric key 2
key50=KEYBOARD 2+^2
; numeric key 3
key51=KEYBOARD 3+^3
; numeric key 4
key52=KEYBOARD 4+^4
; numeric key 5
key53=KEYBOARD 5+^5
; numeric key 6
key54=KEYBOARD 6+^6
; numeric key 7
key55=KEYBOARD 7+^7
; numeric key 8
key56=KEYBOARD 8+^8
; numeric key 9
key57=KEYBOARD 9+^9
; numeric key 0
key58=KEYBOARD 0+^0
; Volume down
key15=KEYBOARD LEFT+^LEFT
; Volume up
key27=KEYBOARD RIGHT+^RIGHT
; channel up
key23=KEYBOARD UP+^UP
; channel down
key28=KEYBOARD DOWN+^DOWN
Pinnacle remote application: http://members.aon.at/cinch/pinnacle/pinna..._type_c_def.zip
It is of course also possible to use extremeno's profiles.ini (remote type B ) with the application.
I would also like to add the profiles.ini with remote type A codes. However, these codes are currently mapped to Pinnacle's Media Center keyboard shortcuts. If you want to use type A remote with DVBViewer you have to assign keyboard shortcuts for it to the ini file yourself:
http://members.aon.at/cinch/pinnacle/profiles.ini
Edited by CiNcH
