Gae41 Posted April 22, 2007 Posted April 22, 2007 I seem to have lost the tunings to some channels such as Movies4Men, Zone Horror, ClassicFM TV etc. When I do a new scan for FREE channels they're either not there or there, but not working. Has anyone got the latest Astra 28 channellist ini file for me to import? Many thanks Gae P.S. Why do I get no audio for some stations like Classic FM? Quote
Lakeuk Posted April 28, 2007 Posted April 28, 2007 They've moved to a transponder that not currently in DVBViewer transponder ini attached on one transponder ini I've updated that should sort you out Quote
mr_chaela Posted April 28, 2007 Posted April 28, 2007 All latest transponder ini files are available here Quote
nigelbb Posted April 29, 2007 Posted April 29, 2007 The transponder ini file for 28.2E that ships with even the very latest version of DVBViewer is months out of date. Perhaps the developers could update it at some time? I know that it's always changing but perhaps a suggestion could be made during the installation that the user download the latest transponder ini files from http://joshyfun.peque.org/transponders/index.html? Quote
Griga Posted April 29, 2007 Posted April 29, 2007 I'd recommend to use TransEdit for scanning (and sending the results to the DVBViewer channellist). It is available in the members area and provides additional scanning facilities. Usually the ZIP contains an up-to-date transponder list for Astra 28° East. TransEdit allows to edit the transponder list and to update it by performing a NIT (Network Information Table) scan. The joshyfun transponder lists do not contain the DVBViewer specific extensions for DVB-S2. Quote
