charlieram Posted April 27, 2007 Posted April 27, 2007 I Know I've asked a similar question before but would this appeal to you? when record is pressed during live TV can we have the option to record timeslots ie. 5 mins, 10 mins, 15 mins, 30mins, 1hour or current program (check epg for remaining time on current program) and have it toggle through all options with a 5 second time delay), you could even include a stop record too and if you really don't want to use the record button what about the red teletext button. How many people would it take to ask before an idea gets implemented or is it truelly as you say 'not a democrazy' ? Quote
Lars_MQ Posted April 27, 2007 Posted April 27, 2007 Good idea, I agree, but with a change, we do it with 1 minute steps and 20 seconds wait time, cause there are users who want differnet times or aren't as fast pressing the buttons. Quote
charlieram Posted April 27, 2007 Author Posted April 27, 2007 Good idea, I agree, but with a change, we do it with 1 minute steps and 20 seconds wait time, cause there are users who want differnet times or aren't as fast pressing the buttons. What about 5 second steps with half hour wait just to cover all bases?!?! seriously though, Do you not think that it could be useful? the times given are only an example, I really like your software compared to the rest for numerous reasons but this is the thorn for me, Maybe if i'd had an option to try the software before I bought it i may not have been so pushy but i just expected (may be naive of me) a feature like that to be standard Quote
Lars_MQ Posted April 27, 2007 Posted April 27, 2007 Oh I exspect a feature like: I press record because i want to manually record something till I stop it (or it reaches the pin the options predefined time) and not play a selection marathon. if you want your instant timer to stop at a certain time, simply adjust it in the recordingwindow. Quote
charlieram Posted April 27, 2007 Author Posted April 27, 2007 (edited) if you want your instant timer to stop at a certain time, simply adjust it in the recordingwindow. have tried that then my lad says i wanted that and this recording, god dad it's not fair anyway your customer support skills are lacking a certain something so why not implement the above feature into the record button? eh? Edited April 27, 2007 by charlieram Quote
charlieram Posted April 28, 2007 Author Posted April 28, 2007 I'm guessing by the lack of a response that this is also a no. Quote
uglyrooster Posted April 28, 2007 Posted April 28, 2007 (edited) There was a script for this some time ago. Check the search function: startrec.vbs CODE sub main(ID) dim timeritem,helper if instant = true then helper = osd.showpopup("Instant.Rec","30min,60min,90min,120min,150min,180min,210min,240min",True) helper = helper +1 set timeritem = timermanager.item(ID) timeritem.endtime = dateadd("n",helper*30,now) end if end sub (Copyright by admi-ral) Edited April 28, 2007 by uglyrooster Quote
charlieram Posted April 28, 2007 Author Posted April 28, 2007 many thanks mate but i did a search for scripts and also startrec.vbs and the only two posts i found are this one and another where you told another user the same, I will have another search but can you point me in the right direction? Quote
uglyrooster Posted April 28, 2007 Posted April 28, 2007 Probably you found this link: http://www.DVBViewer.info/forum/index.php?showtopic=14833 My information is from the first thread about this. I also checked the functionality, it was quite OK but with some minor problems. I don't need it and you might have to change the script to get a better result. All the threads are in German. Quote
charlieram Posted April 29, 2007 Author Posted April 29, 2007 Where do i put the code? I made a new startrec.vbs and pasted in code, enabled scripts but all i get when i press record is a blank messagebox with yes/no ,do i need to put the code in the existing startrec.vbs and if so, Where? Quote
charlieram Posted May 2, 2007 Author Posted May 2, 2007 Does any one use this method that can give me any pointers? Quote
Peter_P8n Posted February 2, 2008 Posted February 2, 2008 (edited) .. when record is pressed during live TV can we have the option to record timeslots ie. 5 mins, 10 mins, 15 mins, 30mins, 1hour or current program (check epg for remaining time on current program) I also need something like this. Sometimes when recording and watching at the same time, I have to leave my home. Would be great if I could right click and select to record for the next 15,30,60,120 minutes or something - while I record. Otherwise I will have to keep recording for HOURS until I return. Regards Peter_P8n Edited February 2, 2008 by Peter_P8n Quote
Moses Posted February 2, 2008 Posted February 2, 2008 What's so wrong / hard about changing the timer, that DVBViewer creats as soon as you start a recording using that red button? Just type in some end time and the recording Stops. Quote
Peter_P8n Posted February 2, 2008 Posted February 2, 2008 (edited) What's so wrong / hard about changing the timer, that DVBViewer creats as soon as you start a recording using that red button? Just type in some end time and the recording Stops. Ohhh! I didnt notice it creates a timer! I like it! Yeah I guess I can use that. (Its _almost_ as good as my suggestion) Thx! Edited February 2, 2008 by Peter_P8n Quote
