joeri Posted April 28, 2007 Share Posted April 28, 2007 Hi, After the recording was done for a program showing DVB-C subtitles, these subtitles are not visible when playing the recorded program. thanks in advance Quote Link to comment
Lars_MQ Posted April 28, 2007 Share Posted April 28, 2007 played with... ? recorded as.. ? Subtitle as in DVBSubtitles or Teletext subtitles? Quote Link to comment
faminoff Posted June 7, 2007 Share Posted June 7, 2007 Have the same problem. Before no problem. After I've made some config changes in DVBViewer: doesn't work no more. Even when looking at the earlier seen recordings that had subtitles the last time I saw them??? - dvb subtitles - recorded in DVBViewer (not the separate recorder) - terratec home cinema - DVBViewer version 3.6 - Windows Vista Home Premium Thankfull for any advice. Quote Link to comment
dezzy Posted June 8, 2007 Share Posted June 8, 2007 - recorded in DVBViewer (not the separate recorder) I have noticed that you can not capture subtitles if you record in the standard DVBViwer .mpg format. Change to .ts recording format using the TS capture plugin available from the members download site. Quote Link to comment
Lars_MQ Posted June 8, 2007 Share Posted June 8, 2007 Use the standard stuff: Set recordformat to ts in the DVBViewer options and select dvbsubtitles. That's what it's for. You don't need external plugins for it. Quote Link to comment
dezzy Posted June 8, 2007 Share Posted June 8, 2007 I think that the Videorecorder Plugin is a brilliant enhancement of the recording facility. In any case, however you get there, recording in .ts format will probably fix the OP's problem. The "standard" DVBViewer recording format .mpg (MPEG2 PS) does not seem to record the subtitles. Quote Link to comment
