Lakeuk Posted April 29, 2007 Share Posted April 29, 2007 Is anyone experiencing high pitched sound on CNN (Astra 28) with DVBViewer Pro, I've viewed the same channel using the TE version that came with my card and the sound for CNN on TE is ok. Comparing the settings on each application the details looks the same - anything a miss? DVBViewer pro settings [Channel0] TunerType=1 Frequency=12051 Polarity=v Symbolrate=27500 FEC=-1 APID=2319 VPID=2317 PMTPID=256 PCRPID=2317 AC3=0 TelePID=2318 SID=7140 StreamID=2018 NetworkID=2 LNB-Selection=1 LNB=10600 DiseqC=0 Root=MyChannels Name=CNN Category=News Encrypted=0 SatModulation=0 SatModulationSystem=0 Group=0 DVBViewer TE settings [Channel298] TunerType=1 Frequency=12051 Polarity=v Symbolrate=27500 FEC=5 APID=2319 VPID=2317 AC3=0 TelePID=2318 SID=7140 PMT=256 LNB-Selection=1 LNB=10600 DiseqC=0 Root=Astra 2A,2B,2D / Eurobird Name=CNN Category=BSkyB Encrypted=0 Quote Link to comment
Griga Posted April 29, 2007 Share Posted April 29, 2007 high pitched sound on CNN (Astra 28) with DVBViewer Pro You are searching at the wrong place. Most likely caused by the CNN mono sound and an audio decoder that isn't able to handle it correctly without getting this information beforehand (MS MPEG Audio, I guess). There are two ways to fix it in DVBViewer Pro. Go to Settings -> Options -> DirectX and 1) select a better audio decoder, if available (recommended) or 2) tick "Audio Format Detection". However, this will slow down channel switching a bit, because it lets the DVBViewer Filter analyse the stream before playback starts. Quote Link to comment
Lakeuk Posted April 29, 2007 Author Share Posted April 29, 2007 Thanks, so simple - changing the audio decoder from <system default> sorted it Quote Link to comment
