Mini Epg?
Hi, i just bought DVBViewer yesterday.
It works really nice, for the first time ever i can watch the HDTV chans, subtitles are working on all chans.
However im missing a function that i used to have in mediaportal, a "miniepg".
you pressed a button on the remote and a menu appeared infront of the tvstream with ~5 chans and whats on them, and you could scroll down an easy and quick see whats on tv.
now i have to press escape, then scroll to the "now" and when im scrolling trough that its really slow to scroll up and down :)
Other then this "problem" im really enjoying DVBViewer.
assing a button for the OSD channellist... you'll see the list of the channels with what's currently played on the actually selected one and scrolling is fast. Or you could use the timeline window... there are many OSD Actions, that you should look into :)
i think i found it, thanks.
Annoying thing is, when i switch a chan i want it to go back to fullscreen tv again automaticly.
As it is now i have to press escape to make it fullscreen again, is it possible to fix that somehow?
it's not possible with the latest release version, yet... (at least not that I know, maybe with some VBScript?)
But in the newest beta version there is a hiddensetting to do just that. -> if you feel confident in using a beta, you could try that, or otherwise wait till it is declared as release version :)
Edited by Moses
Oh, nice, ill play around with it tomorrow.
if i disturb my girlfriends primetime tv watching more then ive already did im gonna be a dead man.
Thanks for the quick reply :blink:
