mai9 Posted May 23, 2007 Share Posted May 23, 2007 in the default software of my card Hauppauge HVR 1100 I can record from the input line, is it possible to do the same with DVBViewer? If it is please, explain how, because I couldn't do it. Quote Link to comment
Lars_MQ Posted May 23, 2007 Share Posted May 23, 2007 Try the TV-Genial / commandline plugin (found in the membersarea). Quote Link to comment
Derrick Posted May 23, 2007 Share Posted May 23, 2007 (edited) *LOL* that could be a classical misunderstanding: >>in the default software of my card Hauppauge HVR 1100 I can record from the input line >Try the TV-Genial / commandline plugin (found in the membersarea). WinTV-HVR-1100 features Digital and Analogue TV for your PC Analogue TV features Record analogue TV shows to your PC's hard disk using our SoftPVR™ MPEG-2 encoder. The DVBViewer is for digital signals only! Edited May 23, 2007 by Derrick Quote Link to comment
Lars_MQ Posted May 23, 2007 Share Posted May 23, 2007 Oh the AV line input. well ok I missunderstood. Quote Link to comment
mai9 Posted May 23, 2007 Author Share Posted May 23, 2007 ok, so I can't use DVBViewer for that purpose, any other program I can use instead of the one that came with the card (which doesn't run very well)? Quote Link to comment
Gioxy Posted May 23, 2007 Share Posted May 23, 2007 Can't know if it work with your card, but a famous powerful one is VirtualDUB (www.virtualdub.org) and it's freeware... Quote Link to comment
mai9 Posted May 30, 2007 Author Share Posted May 30, 2007 Can't know if it work with your card, but a famous powerful one is VirtualDUB (www.virtualdub.org) and it's freeware... thanks for the suggestion at the end I used the program that came with the tv-card because I couldn't figure out how to use virtualDUB. Maybe next time when I have more time I read its manual Quote Link to comment
