nicke_lilltroll Posted May 28, 2007 Posted May 28, 2007 Maybe this isn´t possible at all, but i need to give it a try. I´ve been using a FireDTV-T tuner with both DVBViewer and Windows MCE for a while and it works perfect. Since a couple of weeks i also installed a Technotrend S2-3200 card for sat reception. This card works as good as it might with it´s own software - TT-mediacenter. I mean it works alright but the software sucks!! Therefore I like to use the DVBViewer for both cards. If I deactivate the FireDTV tuner, I can scan and tune in transponders from the TT-card, but when the FireDTV is activated it looks like it blocks all communication with the TT card when using DVBViewer. It´s still visible in the list of devices at the hardware settings, but when I do a scan I only get a couple of hits and they are actually from the FireDTV-t card!!!! I have tried to set the TT-card as "preferred" and the DTV-t card as "no use" but still the same result. There is obviously no hardware conflict, cause FireDTV-t works with the MCE simutaniously as the TT-card works with it´s TT-mediacenter. Is DVBViewer supposed to handle two different cards at the same time or not? Hope someone can shine some light over this issue. Quote
Lars_MQ Posted May 28, 2007 Posted May 28, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
Moses Posted May 28, 2007 Posted May 28, 2007 You must be doing something very strange there... I have a Skystar HD (which is identically to your S2-3200) and two FireDTV-C devices running with DVBViewer as smoth as possible... Quote
nicke_lilltroll Posted May 28, 2007 Author Posted May 28, 2007 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Here is my support.zip file Quote
nicke_lilltroll Posted May 28, 2007 Author Posted May 28, 2007 You must be doing something very strange there... I have a Skystar HD (which is identically to your S2-3200) and two FireDTV-C devices running with DVBViewer as smoth as possible... In deed I am....... but what???? Quote
Lars_MQ Posted May 28, 2007 Posted May 28, 2007 Options -> DirectX -> Audiorenderer back to default directsound device. Quote
nicke_lilltroll Posted May 28, 2007 Author Posted May 28, 2007 Options -> DirectX -> Audiorenderer back to default directsound device. Hmmm........ I really cannot see how that should affect the transponder scanning operation...... The problem is that when I try to scan the TT- card, I get hits from the DTV-card, like providers that is not supposed to be on that satellite distibution at all. It looks as if DVBViewer sets the DTV-card in priority even though the scan dialog says that I use the TT-card. Quote
Lars_MQ Posted May 28, 2007 Posted May 28, 2007 The problem is that when I try to scan the TT- card, I get hits from the DTV-card, like providers that Nope the problem is a "know it all better" user Just do as I said. trust me. Quote
nicke_lilltroll Posted May 28, 2007 Author Posted May 28, 2007 Nope the problem is a "know it all better" user Just do as I said. trust me. OK, with all your respect.... what do you mean..."the problem is a "know it all better" user" I have done this over and over again. Everything works as a charm as long as the DTV card is deactivated in the system-manager. I get all the channels tuned in and running in HD and 5.1 and all. But as soon as i activate the DTV card it´s down the drain again. I have also reinstalled the DVBViewer, did not matter. (Just to let know....Audiorenderer is set back to default directsound device. Doesn´t matter) Quote
Lars_MQ Posted May 28, 2007 Posted May 28, 2007 what do you mean... Just as I said it. (Just to let know....Audiorenderer is set back to default directsound device. Doesn´t matter) If this would have been in the post instead of I really cannot see how that should affect the transponder scanning operation...... i would investigate this further, but I don't wast anymore of my spare time Quote
nicke_lilltroll Posted May 28, 2007 Author Posted May 28, 2007 Just as I said it. If this would have been in the post instead of i would investigate this further, but I don't wast anymore of my spare time I really appreciate that someone takes their time trying to help out others with their problems, but I don´t like when I´ll get treated like some idiot. OK my quote: "I really cannot see how that should affect the transponder scanning operation......" maybe came out a little bit wrong, but the fact is, it did not have anything to do about this. One way or another, I think I´m gonna solve this problem without any rude comments. Quote
