ramonchin Posted June 3, 2007 Posted June 3, 2007 (edited) At first it wasn't able to play Audio-CD. Later after registering cdaudio.ax and cddareader.ax it can play audio-cds. But now the problem is there are a lot of pauses on first songs. I've noticed directsound buffer gets empty quickly. With Windows media player, audio-cds play fine. I'm using last stable DVBViewer pro. Please help. Edited June 3, 2007 by ramonchin Quote
Griga Posted June 3, 2007 Posted June 3, 2007 Later after registering cdaudio.ax and cddareader.ax it can play audio-cds. Both are Audio CD source filters. Decide which one you want to use. Unregister both (just to make sure) and then register only one. For the moment I'd recommend cddareader.ax. However, a new CDAudio.ax version will be available soon (some things have been fixed and enhanced). Quote
ramonchin Posted June 3, 2007 Author Posted June 3, 2007 (edited) Both are Audio CD source filters. Decide which one you want to use. Unregister both (just to make sure) and then register only one. For the moment I'd recommend cddareader.ax. However, a new CDAudio.ax version will be available soon (some things have been fixed and enhanced). Griga I tried it. CDAudio.ax doesn't work. cddareader.ax causes stops on play. Why doesn't wmp cause any problem? Edited June 3, 2007 by ramonchin Quote
Griga Posted June 3, 2007 Posted June 3, 2007 Why doesn't wmp cause any problem? WMP doesn't use DirectShow filters for Audio CD playback. But now the problem is there are a lot of pauses on first songs. I've noticed directsound buffer gets empty quickly. Probably caused by an additional DirectShowe filter inserted by DVBViewer Pro (Audio Selection). It seems to influence buffering in an unfavourable way. Even with enhanced buffering in CDAudio.ax I get these pauses (only few, however), when I play a CD in my slow CD ROM drive. If I use a DVD drive it plays well. Same in DVBViewer GE, if the Audio Selection filter is used. Without it it's ok in any case, the drive doesn't matter. I'll try to find a solution for it. Quote
ramonchin Posted June 3, 2007 Author Posted June 3, 2007 WMP doesn't use DirectShow filters for Audio CD playback.Probably caused by an additional DirectShowe filter inserted by DVBViewer Pro (Audio Selection). It seems to influence buffering in an unfavourable way. Even with enhanced buffering in CDAudio.ax I get these pauses (only few, however), when I play a CD in my slow CD ROM drive. If I use a DVD drive it plays well. Same in DVBViewer GE, if the Audio Selection filter is used. Without it it's ok in any case, the drive doesn't matter. I'll try to find a solution for it. Can Audio Selection filter be disabled? I could try it. Thanks. Quote
Griga Posted June 3, 2007 Posted June 3, 2007 Can Audio Selection filter be disabled? Yes. You can unregister it by using the RadLight Filter Manager (see members area). It appears as "RadLight Audio Select" in the DirectShow section. Select it, and click "Unregister". If you want to re-register it, click "Register" and select the file RLAudioSel.ax. Quote
ramonchin Posted June 3, 2007 Author Posted June 3, 2007 (edited) Yes. You can unregister it by using the RadLight Filter Manager (see members area). It appears as "RadLight Audio Select" in the DirectShow section. Select it, and click "Unregister". If you want to re-register it, click "Register" and select the file RLAudioSel.ax. In directshow I only found Radlight Streaming Source (shoutcast.ax)... Perhaps RLAudioSel.ax is not registered... Edited June 3, 2007 by ramonchin Quote
Griga Posted June 4, 2007 Posted June 4, 2007 Perhaps RLAudioSel.ax is not registered... Or not installed at all. It is included in the DVBViewer GE installation, but not in DVBViewer Pro. So it must be some other problem. Please check which filters show up under View -> Filters when playing an audio CD. I've uploaded a test version of the new (enhanced) CDAudio.ax to the members area -> beta section. Please try how it works. The ZIP contains two batch files. The first one (Register_CDAudio.bat) unregisters cddareader.ax and registers CDAudio.ax, the second one the other way round. Quote
ramonchin Posted June 4, 2007 Author Posted June 4, 2007 Or not installed at all. It is included in the DVBViewer GE installation, but not in DVBViewer Pro. So it must be some other problem. Please check which filters show up under View -> Filters when playing an audio CD. I've uploaded a test version of the new (enhanced) CDAudio.ax to the members area -> beta section. Please try how it works. The ZIP contains two batch files. The first one (Register_CDAudio.bat) unregisters cddareader.ax and registers CDAudio.ax, the second one the other way round. Griga, with this CDAudio.ax filter, I get this message: Cannot render mediafile, error: 0x80040265 Quote
Griga Posted June 4, 2007 Posted June 4, 2007 How do you start playback? Here it works with DVBViewer Pro 3.6.1.20 and DVBViewer GE. Quote
ramonchin Posted June 4, 2007 Author Posted June 4, 2007 How do you start playback? Here it works with DVBViewer Pro 3.6.1.20 and DVBViewer GE. When I insert the Audio-CD a popup ask me for CD autoplay. I choose yes, then the error message is shown. Quote
Griga Posted June 4, 2007 Posted June 4, 2007 Strange. I did exactly the same, and it works with the CDAudio.ax that I've uploaded today. Please check with the RadLigth Filter Manager, if the cddareader.ax is unregistered, and CDAudio.ax is really registered properly. It should appear as "DVBViewer File Source (CD Audio)" in the DirectShow section. Quote
ramonchin Posted June 5, 2007 Author Posted June 5, 2007 (edited) Strange. I did exactly the same, and it works with the CDAudio.ax that I've uploaded today. Please check with the RadLigth Filter Manager, if the cddareader.ax is unregistered, and CDAudio.ax is really registered properly. It should appear as "DVBViewer File Source (CD Audio)" in the DirectShow section. I did it... But the same problems... It takes a long time to play at first and the first songs pause often, although less than before Edited June 5, 2007 by ramonchin Quote
Griga Posted June 5, 2007 Posted June 5, 2007 With different CDs, or only one? What kind of drive are you using? Quote
ramonchin Posted June 6, 2007 Author Posted June 6, 2007 (edited) With different CDs, or only one? What kind of drive are you using? Original CD's play almost fine CD-R... very bad at first songs. In WMP everything is right my drive is a LG DVD-RAM with lightScribe Thanks Edited June 6, 2007 by ramonchin Quote
Griga Posted June 6, 2007 Posted June 6, 2007 Your drive seems to have difficulties to read the CD-Rs properly. Most likely it needs several tries for certain sectors. However, an appropriate buffering strategy can overcome this issue, as WMP proves. I will think about it... Quote
ramonchin Posted June 6, 2007 Author Posted June 6, 2007 Your drive seems to have difficulties to read the CD-Rs properly. Most likely it needs several tries for certain sectors. However, an appropriate buffering strategy can overcome this issue, as WMP proves. I will think about it... Yes, I think that´s the trick. Thanks Griga. Quote
tb99de Posted June 14, 2007 Posted June 14, 2007 For information: I had the problem with suttering sound from a audio-cd with my LG H30N. After use of the new CDAudio.ax 1.0.5 and the beta 3.6.2.25 everything works fine. Quote
Griga Posted June 18, 2007 Posted June 18, 2007 I've uploaded a new test version 1.0.6.2 of the audio CD source filter to the members area, beta section. It uses a different buffering strategy, compared to version 1.0.5, which at least avoids the short pauses that were caused here by RLAudioSel.ax in the filter graph. @ramonchin: Does it solve your problem? Quote
ramonchin Posted June 25, 2007 Author Posted June 25, 2007 I've uploaded a new test version 1.0.6.2 of the audio CD source filter to the members area, beta section. It uses a different buffering strategy, compared to version 1.0.5, which at least avoids the short pauses that were caused here by RLAudioSel.ax in the filter graph. @ramonchin: Does it solve your problem? Still it takes a long time to start playing (like bad sectors were present), and later everything is ok... Thanks. Quote
