nTuomo Posted June 17, 2007 Share Posted June 17, 2007 Hello, My DVBViewer PRO can't find any channels. When I click the 'Scan range' button, the progress bar fills immediately up to 100 % (with a green-to-red-background). Below the bar, there's a text "0 program(s) found". I'm using TechniSat Airstar USB and Windows XP. I have set the following in Settings/Options/Hardware: -Device: DVB file device -Tuner type: Terrestrial -State: Normal (I have also tried 'Preferred'). In 'Scan channels', my choices are: -Reception type: Terrestric -Transponder list: Terrestrial (EUR) -Frequencies are the program recommendations: from 50000 to 858000 KHz. What I have tried: -TechniSat drivers from the TechniSat CD that came with the DVB receiver -the latest TechniSat drivers downloaded from their website -DVBViewer TE-version and GE-version -plug the USB cable to another USB plug I have also tried to install the BDA-drivers that I downloaded from the TechniSat website, but the installation failed. XP system hardware lists 'TechniSat DVB-PC TV Star USB' as functioning correctly. I'm pretty sure that my plug-ins are correctly done because DVBViewer used to work just fine on my computer before my hard disc broke down. But now I am having this mysterious problem. Any help is more than welcome! Quote Link to comment
Lars_MQ Posted June 17, 2007 Share Posted June 17, 2007 Device: DVB file device-Tuner type: Terrestrial -State: Normal (I have also tried 'Preferred'). Well file device does not sound like airstar, does it? Set it to do not use and use your airstar instead. Quote Link to comment
nTuomo Posted June 17, 2007 Author Share Posted June 17, 2007 Well file device does not sound like airstar, does it? Set it to do not use and use your airstar instead. There is no 'Airstar' on the list, only File device, Unicast and Multicast. Any ideas what I should do to get Airstar on the list, too? PS. Thanks for the fast answer! Quote Link to comment
Lars_MQ Posted June 17, 2007 Share Posted June 17, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote Link to comment
nTuomo Posted June 17, 2007 Author Share Posted June 17, 2007 Support tool analysis attached. support.zip Quote Link to comment
Griga Posted June 17, 2007 Share Posted June 17, 2007 DVBViewer can't detect your AirStar, because components are missing that are installed with the TechniSat software, particularly SkyDLL.dll. Quote Link to comment
Lars_MQ Posted June 17, 2007 Share Posted June 17, 2007 You have to install the whole technisat stuff, not only the driver. There are missing several important files now. Quote Link to comment
nTuomo Posted June 17, 2007 Author Share Posted June 17, 2007 (edited) Awesome, it works now ! I really don't understand why the DVBViewer TE -version didn't seem to work earlier. I guess the error was where it always is - not in the computer, but in front of it Now the PRO version works just fine, too. Thank you so much for your kind and fast help! Edited June 17, 2007 by nTuomo Quote Link to comment
