recording improvements
oaks
if you have to record more programs on different channels unattendetly the following features would be nice:
- an option to pause DVBViewer when recording is finished (and until next recording starts) - like the 'shutdown DVBViewer' -_-
- if i set 'disable video only' in the recording dialog, this is set back to default (render video and audio) when channel is switched
- an option to set recording method (.ps, .pva, splitted, etc.) based on input channel (AC3 or not)
and as a separate request:
- record and mux a second audio stream (directly in DVBViewer, not piddump)
bye, oaks.
A solution can be found here. It disables AV rendering permanently, if the SkyStar 4.2 rendercore is selected.
In the next release there will be a solution for Marfi's rendercore too, and I will provide a plugin, that allows to select this state (among some others) easily via menu.
Griga
Hey i didn't know that you work on another solution... a big thank you -_-
