Nils-H Posted August 17, 2007 Posted August 17, 2007 Hi! I was just wondering if Mediahigway EPG is a DVB-S thing only, or does it also exist for DVB-C? If it also applies for DVB-C, how should I configure it, if I (think I) know which channel it is transmitted on? Sorry if this is a stupid question.... Nils-H Quote
Lars_MQ Posted August 17, 2007 Posted August 17, 2007 If you figure out if it exists on dvb-c also, we figure out how to integrate it. Up to now it is DVB-S only. Quote
Nils-H Posted August 17, 2007 Author Posted August 17, 2007 I have no idea, that's why I asked The only thing I know, is that the STB from the provider (Canal Digital in Norway) has a lot more EPG info available than the DVB-EPG in DVBViewer. So after searching around on the web, I saw that OpenTV and Mediahighway was mentioned as systems in STBs that held such information. Is there a tool somewhere that can be used to find out? Quote
boborg Posted August 17, 2007 Posted August 17, 2007 (edited) On DVB-S EPG it is on the same transponder as Sky News, Discovery Civilisation etc. Don't know if you have those channels. If you do try tuning in to one of these and see if more EPG is there. Edited August 17, 2007 by boborg Quote
Benarty Posted August 18, 2007 Posted August 18, 2007 On DVB-S EPG it is on the same transponder as Sky News, Discovery Civilisation etc. Don't know if you have those channels. If you do try tuning in to one of these and see if more EPG is there. if the DVB-C uses MHP (= java) then EPG can also be transmitted via cable and processed with Java so not compatible with the way DVB-S does it. Quote
Nils-H Posted August 18, 2007 Author Posted August 18, 2007 On DVB-S EPG it is on the same transponder as Sky News, Discovery Civilisation etc. Don't know if you have those channels. If you do try tuning in to one of these and see if more EPG is there. That helped a lot! Thanks! Just too bad I have to switch to Sky News to get the EPG updated. Is there a way to schedule this with DVBViewer? Quote
jf2020 Posted August 19, 2007 Posted August 19, 2007 That helped a lot! Thanks! Just too bad I have to switch to Sky News to get the EPG updated. Is there a way to schedule this with DVBViewer? Look here EPGPlus . I think it's what you're looking for. BTW where can I find a list of all Mediahighway services by satellite? Quote
Nils-H Posted August 24, 2007 Author Posted August 24, 2007 Thanks for the tip, but I can't find a way in EPG plus to switch and download EPG from a channel. Is there something I have overlooked? Quote
Tjod Posted August 24, 2007 Posted August 24, 2007 No EPGPlus only use the EPG wich is available in DVBViewer. Quote
