External Command from DVBviewer ?
Help please I need co call external command from DVBViewer,I need tos call external command on channel change with the info on the current satellite for example:
on channel change to call the command: c:\app\app.exe "ASTRA" or some thing like that
is it pssible please help on this depends will I buy or not the DVBViewer
PLEASE HELP :)
You could run an external Application on channel change by adding
OSD.ExecNewProcess "c:\Windows\notepad.exe","", False, False
to the channelchange.vbs.
For the parameter take a look in the "DVBViewer COM Interface" (Members section). DVBVSpy (Members section) shows you available informations.
But i did not find informations about the satellite.
DiseqC Settings and LNB, LNBSelection are items of ITuner. I think channelchange.vbs should get an instance of ITuner, when it's called. I don't know what is in that variables, but maybe you can use one of them. :)
Thanks for the tips, but I still can’t get results,
Tried different variations and nothing, I can’t start the external program please give me an example how exactly to modify the channelchange.vbsin order to start the app,
And second how to get the parameter the cnannelID, I found something thah might work but I need help on how to do it exactly, I could use
IChannelItem = interface(IDispatch)
property Root: WideString;
The name of the group/satellite the entry belongs to. Depends on the channellist of the DVBViewer.
Read only Property.
Or
IChannelCollection = interface(IDispatch)
function GetChannelList(out List: OleVariant): Integer;
Special purpose high speed function to retrieve the channel list as a two-dimensional variant safearray.
List[x,0] := Root;
List[x,18] := Tuner.Diseqc;
Hot to do thatm write sub main(something)….
Or something else…
Please help
