Artè HD working ?
giorusso
Hello m8s,
maybe u already know it but Artè is testing 24/24 in HD (the logo is ArtèHD) on AtlanticBird 5°W freq. 11.555V SR29947 7/8 in Clear Mpeg4...now, I tried to watch it with my SkyStarHD and last drivers/soft (1.0.7.6 (Beta Version)) under my XP system (P4D 3,4Ghz, 3GBRam, and a nvidia 7800GT based video card) but no images only sound; then tried with the CoreAVC codec (1.3 last version I suppose...if there's new one tell me) and some images are shown but very messy...
Even tried with the Vista x64 OS I have in other partition, but still noway...so, if u have further experience please share and tell.
And maybe if u know when ArtèHD is coming on more commercial sat (Astra or HBird) and "easy" bitrates, ur welkome too ;)
Try the MainConcept decoder. Cyberlink yields a black screen and coreavc (1.0) is flickering with lots of green blocks.
Here's the analysis from H264Reader.
Video-PID = 260
profile_idc = 100 -----> high profile
constraint_set0_flag = 0
constraint_set1_flag = 1
constraint_set2_flag = 0
constraint_set3_flag = 0
level_idc = 40 -----> level 4.0
seq_parameter_set_id = 0
chroma_format_idc = 1
bit_depth_luma_minus8 = 0
bit_depth_chroma_minus8 = 0
lossless_qpprime_flag = 0
seq_scaling_matrix_present_flag = 1
seq_scaling_list_present_flag [0] = 0
seq_scaling_list_present_flag [1] = 0
seq_scaling_list_present_flag [2] = 0
seq_scaling_list_present_flag [3] = 0
seq_scaling_list_present_flag [4] = 0
seq_scaling_list_present_flag [5] = 0
seq_scaling_list_present_flag [6] = 0
seq_scaling_list_present_flag [7] = 0
log2_max_frame_num_minus4 = 1
pic_order_cnt_type = 0
log2_max_pic_order_cnt_lsb_minus4 = 6
num_ref_frames = 2
gaps_in_frame_num_value_allowed_flag = 0
pic_width_in_mbs_minus1 = 89 -----> HRes = 1440
pic_height_in_map_units_minus1 = 33 -----> VRes = 1088
frame_mbs_only_flag = 0 -----> interlaced
mb_adaptive_frame_field_flag = 1
direct_8x8_interference_flag = 1
frame_cropping_flag = 1
frame_crop_left_offset = 0
frame_crop_right_offset = 0
frame_crop_top_offset = 0
frame_crop_bottom_offset = -1
vui_parameters_present_flag = 1
aspect_ratio_info_present_flag = 1
aspect_ratio_idc = 255
sar_width = 4
sar_height = 3 -----> aspect ratio 16:9
overscan_info_present_flag = 0
video_signal_type_present_flag = 0
chroma_loc_info_present_flag = 0
timing_info_present_flag = 1
num_units_in_tick = 96
time_scale = 16777216
fixed_frame_rate_flag = 0
nal_hrd_parameters_Present_flag = 1
vcl_hrd_parameters_Present_flag = 0
low_delay_hrd_flag = 0
pic_struct_present_flag = 0
bitstream_restriction_flag = 0
..strange enough according to the reader the width is 1440 pixel but DVBViewer's source filter shows 1920. The current material seems to be up-scaled (pillar box)
...noticed the CoreAVC issue too even with the 1.3 ver....going to try the 1.5 next.
Is there a MainConcept specific h264 codec or is it a hole suite ? Which version ur using ?
Tnx a lot...ArtèHD rules ;)
PS: all right, just ended testing the new CoreAVC 1.5 and the MainConcept and they both work on the channel (maybe the MC a bit better)...but 1 big problem still: no audio-video sincro ;) (under XP and Vistax64)
Edited by giorusso
I'm using Overlay, the latest CyberLink video and the Sonic audio decoder and I got audio and video in sync....
can u tell which version 4 Cyberlink and Sonic ? Ur using which card ? SkyStarHD or Technotrend ? Drivers ?
Tnx.
Edited by giorusso
Tnx.
all right...I did as u suggest and in fact it's working, but in...Alt-DVB (perfect !) :wacko: and only with a Graphedit graph because the very last Cyberlink codecs I own are the ones with the last drivers of my SkyStarHD (beta 1.7.06), so that they are not seen directly from Alt-DVB nor DVBViewer...in DVBViewerGE I tried the GraphPlugin and it's kind of working but image is not very smooth and sound is not sync, maybe I should try in DVBViewer later but I dont know...all this under XP, I'll surely give it a try under Vistax64 later too
But anyway tnx 4 the hint ;)
Edited by giorusso
Hi!
Sonic CineMaster Audio 2.5.03.1282
Cyberlink H.264 Video 7.3.2911 (CL264dec.ax 2.0.0.1709)
Video Renderer: Overlay
Windows XP SP2
TechnoTrend driver 4.4.10.17
All sync and smooth...
