can't watch or listen some channels
mai9
hi, I have some problems listening some channels, I don't know what information give you to help me spot the problem.
Also, there's a channel I can't see, but I can listen. On the channel editor says it's a H.264. I have K-Lite codec pack installed that allows me to watch other HD videos.
thanks for helping :blush:
If you want someone to help you, you must prepare all the information that might be relevant to the problem. Your hardware, logfiles, all of it. But i think you even dont know which channel it is you cant see, now do you?
In that case it might be better to be content which what you cán receive :blush:
Thanks for your replies. I attach the support.zip
The channel I want to watch and can't is "TVC HD". It's from Spain.
My card is Hauppaugge HVR1100. The motherboard is Gigabyte GA-K8NF-9 Rev1.1, and the graphics card: Gecube X1600 Pro 256MB (RX1600PG2-D3)
I didn't know how to "save my directshow system" with redlight, but I could make a DirectShow List, attached aswell :blush:
DirectShow_Filters.txt
I uninstalled K-Lite codec pack, and installed powerdvd 7.3 ultra deluxe and the "TVC HD" can't be seen, yet.
please add a new support zip and select Cyberlink Decoder for all settings in Options->DirectX, especialy for H.264.
Ok, I changed DirectX to Cyberlink, and here's the new support.zip
The good news is that I can see that channel now :( but not on the secondary monitor.
[edit] Now I reinstalled K-Lite codec pack and switched the H.264 DirectX to CoreAVC and it works even on the second screen. It also works with FFdshow, and even with "System Default", so I don't know why it didn't work before. I can also hear the other channel I had problems with.
