aydan Posted September 1, 2007 Posted September 1, 2007 Hi, I'm normally running DVBV in high priority without problems (normal doesn't do it for me because i frequently get discontinuities in the recordings) but somtimes i experience system hangs with this setting. for example just recently when opening a recording with a paused DivX in the viewer. the hang was resolven only after i set the task priority to normal, which took me about 10 minutes because the system wal awfully slow respponding. the viewer was using close to 100% CPU. I think this might have something to do with a busy waiting cycle in the viewer. It wuld be extremely helpful if the "above normal" process priority setting would be available. Aydan Quote
uglyrooster Posted September 1, 2007 Posted September 1, 2007 Look for a tool called "ProcessTamer". It is even possible to reduce the respond time or to set other priorities. Quote
aydan Posted September 1, 2007 Author Posted September 1, 2007 Just tried "ProcessTamer" and it works like a charm. Thanks Aydan Quote
