Can't scan non FTA channels
LePouSAT
Hi !
I just changed my second DVB-S card to a Hauppauge winTV Nova-S Plus, as I checked and saw it is ok with DVBViewer ...
But It is impossible to "lock" on the transponders I am supposed to lock on for my tv channels ...
I only get a very few transponders and only free and crappy channels ... while I should get channels like MTV, VH1 etc ...
I'm using v3.6.1.20 and 3.8.0.0 and same problem in both ...
What could be the problem ?
LePouSAT
EDIT : I have Astra 19.2 on DisecQ A/A and Hotbird 13.0 on disecQ A/B ... Everything is ok if I do the scan on Hotbird ... Any idea someone ?
Edited by LePouSAT
Hi !
LePouSAT
If you can, trie the card without diseqc and see how it scans. How is your signal strength?
Thats ok, the hauppauge card has no CI so you can't get encrypted channels.
I found my problem ... It came from the DisecQ switcher that was out of order ...
I changed it and everything is ok now ...
LePouSAT
