os1 Posted September 3, 2007 Posted September 3, 2007 Hi I have dish with 4 lnbs and a diseqc switch that is working perfect on my regular satellite receiver. I receive 1 deg. W, 13 deg. E, 19 deg. E and 28.2 deg. E. But on my HTPC I can only get DVBViewer to work with one lnb without the diseqc switch. ? I've tried to use all the diseqc settings. opt A/A for 1 deg. W opt B/A for 13 deg E etc. When it's scanning for channels there is no signal. I'm using Technotrend S2-3200 card. Does anyone know what the problem could be? I'd appreciate any suggestoins Quote
os1 Posted September 4, 2007 Author Posted September 4, 2007 I figured it out I think. The driver I was using for Technotrend s2-3200 card was the beta version. When I switched to the original driver (4.4.10.18) I got it to work with 4lnbs 1W 13E 19E and 28.2E Quote
sunzi Posted September 5, 2007 Posted September 5, 2007 Hi OS1, I very much have the same problem like you had. 3 LNB's (LNB1 for Astra 19.2, LNB2 for Hotbird 13.0 and LNB3 for Astra2D/Eurobird on 28.2) are feeding a multiswitch. REception via Topfield receive works fine. However, I don't get my TT connect S2-3600 to work (USB card) Could you elaborate a bit what fixed your problem. Sunzi Quote
igm Posted November 1, 2007 Posted November 1, 2007 When I switched to the original driver (4.4.10.18) I got it to work with 4lnbs 1W 13E 19E and 28.2E Hi os1, I am using TT drivers v5.0.0.2 (beta) dated 2007-05-02 with TT S2-3200 CI. My setup is similar to yours (diseqc switch 4/1 with 4 LNBs on multifeed @ 13,19.2,23.5,28E) on XPSP2. No problems at all: works flawlessly both locally and over network via DVBServer. Quote
ripan Posted April 16, 2008 Posted April 16, 2008 Hi os1,I am using TT drivers v5.0.0.2 (beta) dated 2007-05-02 with TT S2-3200 CI. My setup is similar to yours (diseqc switch 4/1 with 4 LNBs on multifeed @ 13,19.2,23.5,28E) on XPSP2. No problems at all: works flawlessly both locally and over network via DVBServer. Hi, and what is your settings of the DVBViewer Diseqc properties for each one of your received sattelites? That is, please answer the following questions. LNB1 has the following DVBViewer Diseqc properties settings = LNB2 has the following DVBViewer Diseqc properties settings = LNB3 has the following DVBViewer Diseqc properties settings = LNB4 has the following DVBViewer Diseqc properties settings = regards /Ripan Quote
Darwin Posted April 16, 2008 Posted April 16, 2008 My driver-version is 5.0.0.15 lnb/switch - list : Pos A / Opt A > LNB1 [or DiSEqC-Port1 or DiSEqC A or ~AA] Pos B / Opt A > LNB2 [or DiSEqC-Port2 or DiSEqC B or ~BA] Pos A / Opt B > LNB3 [or DiSEqC-Port3 or DiSEqC C or ~AB] Pos B / Opt B > LNB4 [or DiSEqC-Port4 or DiSEqC D or ~BB] Quote
ripan Posted April 16, 2008 Posted April 16, 2008 My driver-version is 5.0.0.15 lnb/switch - list : Pos A / Opt A > LNB1 [or DiSEqC-Port1 or DiSEqC A or ~AA] Pos B / Opt A > LNB2 [or DiSEqC-Port2 or DiSEqC B or ~BA] Pos A / Opt B > LNB3 [or DiSEqC-Port3 or DiSEqC C or ~AB] Pos B / Opt B > LNB4 [or DiSEqC-Port4 or DiSEqC D or ~BB] Many thanks /Ripan Quote
moff Posted August 23, 2008 Posted August 23, 2008 23/8 test, Vista,drivers ver 5.0.0.19 still has such problem , diseqc 4 lnb only work in LNB 1 .driver prolem? help! Quote
Araj Posted August 25, 2008 Posted August 25, 2008 My driver-version is 5.0.0.15 lnb/switch - list : Pos A / Opt A > LNB1 [or DiSEqC-Port1 or DiSEqC A or ~AA] Pos B / Opt A > LNB2 [or DiSEqC-Port2 or DiSEqC B or ~BA] Pos A / Opt B > LNB3 [or DiSEqC-Port3 or DiSEqC C or ~AB] Pos B / Opt B > LNB4 [or DiSEqC-Port4 or DiSEqC D or ~BB] Thanks for that, just what I was looking for. Another point: I'm setting up 3 LNBs (Hotbird 13.0, Astra 19.2, Astra2D/Eurobird 28.2) on a 4x multiswitch. Does it make any difference which LNB goes in which socket of the multiswitch ? Quote
