Klausing Posted August 6, 2003 Posted August 6, 2003 Sometimes i record some things over night. But i dont want shutdown the pc after recording, because there is an other programm running. I only want close the viewer. Can you insert this option additionally in the PVR menu? cheers Steffen Quote
Griga Posted August 7, 2003 Posted August 7, 2003 There are two possibilites: - Close DVBViewer, as requested - Switch DVBViewer to standby mode (no channel tuned, no audio/video rendering, but still able to perform timer recordings). Which one would be prefered? Griga Quote
Guest Oliver Posted August 7, 2003 Posted August 7, 2003 The first one, although I've already asked for this some weeks ago. Bye, Oliver Quote
Klausing Posted August 7, 2003 Author Posted August 7, 2003 I would prefer the first version. @Oliver: maybe you was not loud enough Steffen Quote
Griga Posted August 7, 2003 Posted August 7, 2003 Personally I would prefer the standby mode, because it's more flexible - it allows to keep the DVBViewer waiting in the backround for the next timer event, without charging the processor. But probably you have a special reason for wanting the DVBViewer to be closed - tell me. Griga Quote
Klausing Posted August 8, 2003 Author Posted August 8, 2003 why we cant have both? But probably you have a special reason for wanting the DVBViewer to be closed - tell me Some mpg2 filter (like NVIDIA) make problems if we use standbymode oder disabled video. The other thing is, that every programm which is running without function have some memory in use and not every people have so much memory like me. One look in the taskmanager and you can see that the DVBViewer need over 30MB Memory. The next is, more opened programms can have more unwanted interaction and make problems. And i think you know what a lot of problems directshow can making less opened prgramms --> less unwanted interaction --> less pc problems Thats my experience from my job. Steffen Quote
Guest Oliver Posted August 8, 2003 Posted August 8, 2003 When a program is no longer needed I just want it closed. There's no need for it to take up resources any longer. Bye, Oliver Quote
Guest hackbart Posted August 12, 2003 Posted August 12, 2003 Option for "just close" is now inside.. Christian Quote
