HD on internal graphics chip !
pastimer
Hi everybody,
My Geforce 8500 is for sale. I have never used it.
I bought a mAtx board based on the nvidia 7050 chipset (mine is from Asrock), overclocked the amd x2 BE-2300 cpu to 2.6 Ghz without any special cooling and am looking at smooth h.264 1080p pictures from BBC-HD and Astra-HD. CPU load is around 65%.
Atmitted: I am streaming over the network, so i have no dvb-cards in the machine installed. Power consumption is around 75 watt for the system, so it can be made passively cooled quite easily, although i expect to use one or two large slow turning case fans anyway.
Costs are low. The board costs 55-60 euro. The cpu around 75. You need 2 gig ddr2 pc5300 ram. You can take-off then.
I must say i am absolutely flabbergasted about this chipset and very happy indeed!
Regards, Eppo
Edited by pastimer
  • Like 1
1080i pictures.
And they're not the most stressful H.264 channels around too.
1080i pictures.
Anxine also no problem 1080p :radscorpion:
Anixe HD is a free german HDTV station, where most of the broadcasted material is upscaled PAL (often a "bit" better than PAL but not HDTV quality). E.g. they broadcast Laurel&Hardy very often.
Link: http://www.anixehd.tv/
I know Anixe HD, but is Anxine Anixe? Sure it's not 1080p anyway...
