Comskip Plugin
Hi!
I've copied the zip content to the DVBViewer folder, everything looks in place but nothing happens. How is it activated?
There's no option to activate in the options pannel so i'm a bit lost. No documentation too. Perhaps there is some info in the german section but i dont understand german... i've tried to dig it but with no sucess. :radscorpion:
Can anyone give me a clue?
I've used comskip with good results in GBPVR... its a great little tool.
My specs:
Pc 2.4 1gb RAM
XP SP2
DVBViewer 3.8.0
SS2 v2.6
Thanks in advance!
As fare as i know there is no Comskip Plugin for the DVBViewer. GBPVR Plugins did not work with the DVBViewer.
There is a plugin. It's a little bit older, but it should work, I just can't remember how it was :radscorpion:
I was playing around with comskip today and I'm thinking of reworking the stuff, if I find the time.
OK i found it here.
But i did not have the Time to try it at the moment.
Ok, thanks.
I'll hold until some new info or plugin comes.
  • 4 months later...
Hi!
There's no option to activate in the options pannel so i'm a bit lost. No documentation too. Perhaps there is some info in the german section but i dont understand german... i've tried to dig it but with no sucess. <_<
Thanks in advance!
I tried this too, but no result. Any News?
