SamAlone Posted September 25, 2007 Share Posted September 25, 2007 Hey! Im using latest DVBViewer offcourse, i have had it working awhile with no problems, im running Windows Vista Ultimate 32bit version, im running DVBViewer from c:\DVBViewer and as Admin. Now to the problem, i use DVBViewer with Canal Digital, and i have this problems with channels that stops working, as i told it worked awhile but has started to behave weird.. a specially TV4 and some others, its always the same channels that stops working, changing to MotorsTV it and it work, the only way to get TV4 to work again is to reboot the computer !! then i get it to work until i change channel again, then all these channels stops working and always same channels works, this is really weird.. its like it drops the signal on these channels, as a channel scan doesnt work either, ive tried to change diseq switch and so on as i tought it was some other issue.. Is this bad Vista drivers for my DVB card or what ? anyone else has this issue ? Im using a Twinhan AD-400 DVB-S2 card. Thx ! Quote Link to comment
SamAlone Posted September 25, 2007 Author Share Posted September 25, 2007 (edited) For example i noticed now, when it stops work it behaves like this. These channels doesnt work: Canal + Film 1 Canal + Film 2 VH1 But this channel works as a example Canal + Film 3 VH1 Classic Dont know if this problem is transponder linked ? but i dont think it should mather. For me it should either work or not. Edited September 25, 2007 by SamAlone Quote Link to comment
SamAlone Posted September 26, 2007 Author Share Posted September 26, 2007 No one ?? its really frustrating ;( Quote Link to comment
