faminoff Posted September 26, 2007 Posted September 26, 2007 Hi, I have an Asus My Cinema-P7131 Hybrid card (Digital & Analog). Would it be possible to listen to FM radio with the DVBViewer with this card? If so, how do I set up the FM channels in DVBViewer? BR Dosse Quote
Griga Posted September 26, 2007 Posted September 26, 2007 Would it be possible to listen to FM radio with the DVBViewer with this card? No. It's a DVBViewer. You could as well try to receive digital television with your FM radio Quote
faminoff Posted September 26, 2007 Author Posted September 26, 2007 Thank you. I guess the name DVBViewer is not describing the product fully because the V stands for Video, however you can also listen to Digital Broadcasted Radio with the DVBViewer. So the right name should be DV&RBviewer&Listener. Moreover you can listen to music, DVDs and look at pictures with DVBViewer. So the only thing in the name that applies to all is that it's Digital. I guess however, it wouldn't be much of a problem to add analogue radio to the possibilities of DVBViewer??? It would be really nice if you could replace your whole stereo + video equipment with DVBViewer! Quote
Lars_MQ Posted September 26, 2007 Posted September 26, 2007 I guess however, it wouldn't be much of a problem to add analogue radio to the possibilities of DVBViewer??? Wrong guess. Very complicated, it will never happen. Did you ever try to play a vinyl record with a cd player? Quote
Derrick Posted September 26, 2007 Posted September 26, 2007 Well it's not quite like that When capturing analog signal on a PC, the signals are converted to digital. There are other sources that can be played by the DVBViewer (e.g. iptv), not only DVB. No, you can't play vinyls on a cd player, but you can connect a turntable to an amplifier or a pc Quote
Lars_MQ Posted September 26, 2007 Posted September 26, 2007 MY point was proving the "not complicated" part wrong. No, you can't play vinyls on a cd player, but you can connect a turntable to an amplifier or a pc And your point is? He should put a fm-radio besides his computer? Quote
Derrick Posted September 26, 2007 Posted September 26, 2007 ..my point is (referring to your example) that the DVBViewer is neither a cd player nor a turntable but should play music from both sources Quote
