vipersan Posted September 29, 2007 Posted September 29, 2007 Hi friends.. Im using the latest DVBViewer pro with an S2-3200 pci card and have scanned most of the channels I have access to on my usals dish... ..Im now interested in scanning for S and S2 feeds on some of the more obscure sats .. However it seems I dont have full control of search parameters ... On the channel scan menu I can enter transponder freq (selecting none for sat data)...and I can set the symbol rate to search... ..but there doesn't appear to be any way to manually set S or S2 or to set the FEC ... Is there a way around this ...or have I missed something ? rgds VS Quote
Lars_MQ Posted September 29, 2007 Posted September 29, 2007 the pro is not for feedhunting. It's for watching TV. Try transedit, there you have more control. Quote
vipersan Posted September 29, 2007 Author Posted September 29, 2007 the pro is not for feedhunting. It's for watching TV. Try transedit, there you have more control. Thanks for the quick reply Lars .. I would have prefered to perform both tasks with dvbV as its such a pleasure to use ...and works well with Vista... I was trying to avoid cluttering my newly built media centre pc with too many applications....as I usually do with my main pc ... but at least I know it isn't possible now ...so I wont waste any more time trying .. rgds Quote
Griga Posted September 29, 2007 Posted September 29, 2007 I was trying to avoid cluttering my newly built media centre pc with too many applications TransEdit is just a 446 kb DVBViewer add-on resp. scanner tool. Read this. However, it doesn't support USALS yet. Quote
vipersan Posted September 29, 2007 Author Posted September 29, 2007 TransEdit is just a 446 kb DVBViewer add-on resp. scanner tool. Read this. However, it doesn't support USALS yet. Much appreciated Griga ...very useful info Usals control wont be a problem ...as my media pc doesn't drive the dish directly.. I use a loop through from another receiver to the MPC .. I deliberately chose this arrangement as I'd read the S2-3200 doesn't support usals ...and the current drawn through the card to drive the motor would likely result in damage.. rgds Quote
vipersan Posted September 29, 2007 Author Posted September 29, 2007 @Griga I've downloaded Transedit ....and it does exactly what I need it to do ...but after scanning ..I cannot export the channels collected to DVBViewer ... An error is returned that ' DVBviewerpro GE not detected' ... Is Transedit incompatible with DVBViewer pro 3.8.0.0 ? Thanks for any help offered.. rgds Quote
Griga Posted September 29, 2007 Posted September 29, 2007 I cannot export the channels collected to DVBViewer TransEdit.exe must be stored in the DVBViewer program directoy (where DVBViewer.exe is located). Quote
vipersan Posted September 29, 2007 Author Posted September 29, 2007 TransEdit.exe must be stored in the DVBViewer program directoy (where DVBViewer.exe is located). Doh ... Silly me I hadn't thought of that Nevertheless ...I'll take this opportunity to congratulate both you and Lars for a superb and very useful application.. rgds VS Quote
