avoidz Posted October 9, 2007 Posted October 9, 2007 Since installing version 3.9 my AutoPlay Handlers aren't working correctly. Whenever I insert CDs or USB devices I only get an option to Play with DVB or 'Take no action'. Has DVBViewer taken over my AutoPlay settings? Cheers Quote
Moses Posted October 9, 2007 Posted October 9, 2007 That's a bug of the 3.8 deinstaller, if I remember correctly. It did remove all AutoPlay Handlers. Did you deinstall 3.8? Quote
avoidz Posted October 9, 2007 Author Posted October 9, 2007 (edited) That's a bug of the 3.8 deinstaller, if I remember correctly. It did remove all AutoPlay Handlers. Did you deinstall 3.8? Thanks for the info. Nuts. Well I did uninstall 3.8 after I realised (in Add/Remove Programs) that 3.9 didn't over-install/update 3.8, like a lot of programs do. So now my question is: How do I get my AutoPlay Handlers back? Microsoft's AutoPlay Repair Wizard doesn't detect a problem and can't fix it. Anything else I can try? Cheers. Edited October 9, 2007 by avoidz Quote
Dvb-tv Posted October 21, 2007 Posted October 21, 2007 (edited) Anyone help with this? Thanks Don't know about vista. But on reliable xp1 or 2 (is xp2 reliable yet?) Control Panel > Add Or Remove Programs > Set Program Access Defaults Any others you need, someone else might add their suggestions. Sub note to forum parents. I edited my post within 1 second of posting to add an r to an O = Or. Now it says last edited by name time. What gives, don't you have a one minute grace for quick corrections. I haven't visited any other forum the does the same as this forum does. Placing edit name date time etc makes the post untidy, where it could be Nice'n'Neat. Edited October 21, 2007 by Dvb-tv Quote
avoidz Posted October 22, 2007 Author Posted October 22, 2007 Well I couldn't find any way to fix my messed up autoplay, so I disabled it altogether on all my removable media drives. Not a totally satisfactory solution, but it works Quote
