ramonchin Posted October 13, 2007 Posted October 13, 2007 I have last DVBViewer version. Everytime DVBViewer starts, Pan&Scan (under zoom option) goes to 43... The aspect ratio is "none". How could i set 0 for pan&scan forever? Thanks. Quote
ramonchin Posted October 14, 2007 Author Posted October 14, 2007 (edited) Should I erase or modify Setup.xml ?? Is it related to "Recalls" ? Edited October 14, 2007 by ramonchin Quote
djdul Posted October 23, 2007 Posted October 23, 2007 had the same strange bug: the default button do not reset to 100% Quote
atener Posted October 23, 2007 Posted October 23, 2007 Hi Also have problems with the zoom. Every time i start DVBViewer v3.9 the zoom starts in "default" (no adjustment at all) and i need to press "aspect button" then DVBViewer change to my settings! if i use the osd to check my settings i well see that it is "default" for 100ms sec, then it changes to my settings. and yes i have set the zoom both for 4:3 and 16:9 but the problem remains. /aTENEr Quote
terssi Posted November 5, 2007 Posted November 5, 2007 I too have the zoom bug. When I start DVBViewer and go to the zoom menu, all the sliders are in the center. But when I push the Recall #0 button a few times, so it comes back to the Recall #0, then it show the correct zoom settings that I have made. I've tried uninstalling and reinstalling, but no change. A similar bug is with the timers. I am able to create a recording timer, but if I close DVBViewer and the open DVBViewer, it has vanished from the timer menu. Same thing with the favorite channels. If I try to delete the default favourite channels (Prosieben, SAT.1, kabel eins, DAS VIERTE, etc...), they will reappear in the channel menu, when I restart DVBViewer. Quote
Moses Posted November 5, 2007 Posted November 5, 2007 I too have the zoom bug. When I start DVBViewer and go to the zoom menu, all the sliders are in the center. But when I push the Recall #0 button a few times, so it comes back to the Recall #0, then it show the correct zoom settings that I have made. I've tried uninstalling and reinstalling, but no change. It's a known bug in 3.9 with some aspect ratios. AR "auto" is working correctly. It will be fixed in the next version. A similar bug is with the timers. I am able to create a recording timer, but if I close DVBViewer and the open DVBViewer, it has vanished from the timer menu. Same thing with the favorite channels. If I try to delete the default favourite channels (Prosieben, SAT.1, kabel eins, DAS VIERTE, etc...), they will reappear in the channel menu, when I restart DVBViewer. It seems like DVBViewer has insufficient rights to write in it's configuration folder. You should check that. Quote
