protek Posted October 16, 2007 Posted October 16, 2007 I have version 3.9.0.0 at the moment but I experienced the following behavior with 3.8.0.0 also. Sometimes, when I shut down the DVBViewer application (mostly, when I set the timer for recording), the process of the DVBViewer isn't stopped. This causes that I'm not able to start DVBViewer again if I don't reboot XP. The easiest way to see that the process is still running is to start DVBTaskScheduler that states that DVBViewer is still running. Other way is to restart DVBViewer, which it will not do. Also the process cannot be killed manually from the process window so I'm left with the option of rebooting Windows. I have a Hauppauge WinTV Nova-T Stick and Windows XP SP2. I've tried to uninstall previous versions very thorougly prior to installing newer version. At first it appears to help but soon the process problems begin to appear. Anyone else experiencing similar kind of behavior? Quote
Lars_MQ Posted October 16, 2007 Posted October 16, 2007 please rename the plugins folder in the DVBViewer program folder to plugins1. Does it work then? Quote
protek Posted October 16, 2007 Author Posted October 16, 2007 please rename the plugins folder in the DVBViewer program folder to plugins1. Does it work then? Thanks for the tip! Will try that when I get home. Quote
protek Posted October 17, 2007 Author Posted October 17, 2007 I tried renaming the plugins folder and it seems to work now. At least I couldn't repeat my problem with half a dozen sequential shutdowns and restarts of DVBViewer in different situations. Thanks once more! Is there some reason why the renaming of plugins folder enables the process to shut down properly? Quote
Lars_MQ Posted October 17, 2007 Posted October 17, 2007 well it seems one of the plugins is a troublemaker. You could start now and put one by one plugin back into the plugins folder to see which is the culprit. Quote
protek Posted October 28, 2007 Author Posted October 28, 2007 Turns out that the plugins weren't the culprit after all. I still had the plugins folder renamed. I started DVBViewer from fresh boot, switched channel and switched over to EPG. I selected a program to be sent to PVR, checked from recording options that the format was still MPG and set from Timer menu that the PC would shut down after recording. I then closed DVBViewer and opened DVBTaskScheduler to set the task for Windows. Scheduler claimed that DVBViewer was still running and DVBViewer wouldn't start anymore. I had to reboot my PC and do everything all over again. Quote
