Fabien44 Posted October 26, 2007 Share Posted October 26, 2007 Hello, i receive DVB-T in France (called TNT) and i face some tearing and freezes sometimes. I tried intervideo and Leadtek codecs. I wonder if there is a proper codec dedicated to the mpeg 2 DVB-T decoding? Regards Fabien Quote Link to comment
Moses Posted October 26, 2007 Share Posted October 26, 2007 Try the one from cyberlink (which comes with PowerDVD). The tearing problems could be wrong deinterlace settings... try to have a look at view->filters and click on the MPEG2 Decoder, this should open the settings page for the decoder and have a look for deinterlacing options. Freezes are mostly produced by bad signal. Have a look at view->filters->DVB Source and in it the Discontinuties value. This should stay 0 all the time for a perfect signal. If it goes up while the picture freezes, you know that your freezes come from signal interceptions. Then you should try to move the antenna to a better place or buy a better one. Quote Link to comment
Fabien44 Posted October 26, 2007 Author Share Posted October 26, 2007 Try the one from cyberlink (which comes with PowerDVD). The tearing problems could be wrong deinterlace settings... try to have a look at view->filters and click on the MPEG2 Decoder, this should open the settings page for the decoder and have a look for deinterlacing options. Freezes are mostly produced by bad signal. Have a look at view->filters->DVB Source and in it the Discontinuties value. This should stay 0 all the time for a perfect signal. If it goes up while the picture freezes, you know that your freezes come from signal interceptions. Then you should try to move the antenna to a better place or buy a better one. Thanks Moses, i will try this. For the freeze, i test with an external DVB-T receiver (a pioneer one) and no tearing and no freeze, it works perfectly with the same orientation of the antenna. Quote Link to comment
