Bombardier Posted October 29, 2007 Share Posted October 29, 2007 (edited) Can you tell me what happens here, and how can I fix it? svcdebug.log 12.10.2007 17:27:42 ThdProc Dispose WT 12.10.2007 17:27:44 Resume PBT_APMRESUMESUSPEND 12.10.2007 17:27:44 StartService create plugin list 12.10.2007 17:27:44 StartService start timer 12.10.2007 17:27:44 StartService loadchannellist 12.10.2007 17:27:45 Hardware.InitDevice Load settings for: Cinergy 1200 DVB-T Tuner (BDA) 12.10.2007 17:27:45 Hardware.InitDevice Load settings for: Generic BDA Tuner Filter (2) 12.10.2007 17:27:49 loadsetup load vcr 12.10.2007 17:27:49 StartService load setup 12.10.2007 17:27:49 Recorderservice Enabled 12.10.2007 17:30:00 VCR-Internal Starting recording process. 12.10.2007 17:30:00 Opendevice Found Terratec 12.10.2007 17:30:00 Allocate Hardware Cinergy 1200 DVB-T Tuner (BDA) 12.10.2007 17:30:00 VCR-Internal Found fitting Hardware: Cinergy 1200 DVB-T Tuner (BDA) 12.10.2007 17:30:00 DoRecord Finding EPG 12.10.2007 17:30:00 DoRecord Emmerdale 12.10.2007 17:30:00 TDVBHardware.SetTuner PMT: 256 - SID: 49 12.10.2007 17:30:00 StartRecording: MTV3 12.10.2007 17:30:00 VCR-Internal Recording did start. 12.10.2007 18:05:01 Release Hardware Cinergy 1200 DVB-T Tuner (BDA) 12.10.2007 18:05:01 Destroy Hardware Cinergy 1200 DVB-T Tuner (BDA) 12.10.2007 18:05:32 Setting next recording in: 12.10.2007 19:57:00 12.10.2007 18:05:32 ThdProc Enter 12.10.2007 18:05:32 savesetup save vcr 12.10.2007 18:05:32 Stop Couninitialize 12.10.2007 18:05:32 Recorderservice Disabled 12.10.2007 18:05:32 StopService stop service 12.10.2007 18:05:32 Standby PBT_APMSUSPEND svcrec.log 12.10.2007 18:05:01 \\VERKKOLEVYT\Volume_1\tv-tallennukset\Emmerdale_MTV3_10-12_17-30-00.ts Discontinuities: 0 - Total size: 0,00 KB There's a timed recording for 17:30 for 30 mins and it seems to start and end ok, but the result is a 0,00 KB file. This happens every now and then. Once I caught the software "red handed" and the service control (the tray app) stated that the service is recording, but the hd light of my NAS wasn't blinking and there was a 0 KB file found there. So, can you suggest to me how can I find the cause of this and how do I fix it? Edit: the subject is misleading, since today I had a problem with the DVBViewer application. What happened was that I couldn't get no image when trying to view tv and when I tested recording it resulted in a 0KB file... Apparently the Cinergy "freezes" sometimes on the first "access" after boot and that causes a zero size file. Also it requires a reboot or hibernate/resume for it to start working again. Any ideas on how to fix this in the light of the new info? Drivers should be the latest, or at least I couldn't find any newer version yesterday. Edited October 30, 2007 by Bombardier Quote Link to comment
