TT-3200 and DISEQC 1.2/VISTA
Curlo
Hello!
I have problem with latest version of DVBViewer and S2-3200 card with vista. I can turn my moteck diseqc 1.2 motor using USALS goto angular
using this combination:
Vista
3.9 DVBViewer Pro
Technotrend BDA 4.4.10.18 drivers
BUT Not working with this:
Vista
3.9 DVBViewer Pro
Technotrend BDA 5.0.0.2/5.0.0.6 drivers
Technotrend has changed something in drivers so are you supporting USALS/diseqc1.2 commands in latest technotrend drivers?
Reason why I would like to use latest drivers is DVBViewer signal meter which shows always 100% with 4.4.10.18 and VISTA.
5.0.0.6 drivers show signal level right but don't work with diseqc 1.2. Signal level is quite important setting up motor antenna system.
Or Am i doing something wrong here.
I tried the 5 series BDA drivers with XP - no diseqc 1.2.
Had to revert back to 4.4.10.18
Why don't you ask these questions to this address?
here it is
Because they know, that there have been changes in the interface, but DVBV implemented all modifications except the ones for DiseqC.
All the TT users with motors waiting for this repair.
dvbcharly
dvbcharly
Exactly! This is the reason why I ask here, because the way I have understood there is nothing wrong with the drivers only problem is diseqc support from DVBViewer (for 5.x drivers), or is it that it's impossible with 5.x to implement diseqc support.
Not yet proven. Just an assumption. May also be a driver bug.
