ascull Posted November 3, 2007 Share Posted November 3, 2007 hello i was wondering if anyone has managed to install two skystar cards in a windows XP pc at once? i've just tried and am getting a lot of conflicts - symptoms ranging from blue screens, to cards not working at all - and showing as not working in device manager. both cards are installed properly and work fine when the other is removed. is there a particular trick to doing this, or is it just not possible? Quote Link to comment
hdv Posted November 3, 2007 Share Posted November 3, 2007 Hello, its possible, you must use a driver 4.4.0 or higher. http://www.technisat.com/?site=service/dow...;produktID=1281 Quote Link to comment
ascull Posted November 3, 2007 Author Share Posted November 3, 2007 Hello, its possible, you must use a driver 4.4.0 or higher. http://www.technisat.com/?site=service/dow...;produktID=1281 thanks! will upgrade drivers now and let you know how i get on Quote Link to comment
ascull Posted November 3, 2007 Author Share Posted November 3, 2007 thanks! will upgrade drivers now and let you know how i get on thanks again for the help. i've installed the new drivers, and the cards are now working fine. but DVBViewer pro still doesn't pick up the new card. i've installed v3.9, which i think is the latest version, but it's still not working. is there perhaps a setting i'm missing? Quote Link to comment
hdv Posted November 3, 2007 Share Posted November 3, 2007 Hello, had you made a new Hardware scan? in options -> hardware? if this not help, please make this How to post problems/bugs correctly! -> support.zip Quote Link to comment
ascull Posted November 3, 2007 Author Share Posted November 3, 2007 (edited) hi there thanks for your reply i've attached the support.zip file yes, i had tried to rescan for the second card, but it doesn't make any difference. both cards are definitely working. when i disable one in device manager, DVBViewer works fine, and when i enable it and disable the other, DVBViewer still works. thanks for your help! support.zip Edited November 3, 2007 by hdv Quote Link to comment
hdv Posted November 3, 2007 Share Posted November 3, 2007 Hello, in your system is not a driver 4.4.0 or higher installed. take a look in support.zip -> Systeminfo.txt System:------- DVBViewer Version: 3.9.0.0 DVBServer Version: 3.9.0.0 Skydll Path: F:\WINDOWS\System32\Skydll.dll Skydll Version: 4.3.0.9999 the SkyDll.dll is now saved in C:\Program\TechniSat DVB\bin\please deinstall all TechniSat software an driver, after that delete the Skydll.dll in F:\WINDOWS\System32\ restart the pc and make a new installation with a driver 4.4.0 or higher Quote Link to comment
ascull Posted November 3, 2007 Author Share Posted November 3, 2007 thanks!!! will try that now. Quote Link to comment
ascull Posted November 3, 2007 Author Share Posted November 3, 2007 all is now working fine. thanks so much! :( Quote Link to comment
