Twinham Mantis CI decoding problem
ALP
I am attempting to migrate to a PC based sat receiver. I have the PC, sat card,
sat dish configuration listed at the bottom of this post.
The problem is that I cannot seem to receive/decode BBC Prime.
Using the scan function I have scanned the available sats and then
selected the "BBC Prime" that mactches the fequency we use on the standard
receiver box. I see some teletext information displayed but no picture or
sound ever starts.
When I do "View/show cam" DVBViewer shows the cam card as expected with the
viaccess smart card. The CI module Im using is a Firecrypt Dragon Twin with
the viaccess card inserted in it. I have just taken this card out of the CI
slot in the standard top box receivers CI slot and push it into the one in
the Twinham Mantis CI card. (I tried the card being present on boot and
inserting it after a boot). The card still works in the top box receiver
so I have not blown it up .....
The DVBViewer "Settings/options/Hardware" the following options are clicked.
has CI module
DVB-S2
Is there any way I can check if the card is decoding or not ?
Any ideas how I cam proceed ?
Many thanks for any help
Andy
PC: E6750 @ 2.66GHz Duo CPU
2GB RAM
XP sp 2
With a Azurewave card
AD- SP400 (1041+4046) ie Twinham Mantis
Driver versions 1.0.5.9 [29/05/2007]
Technisat Multytenne 45 dish
controlled via a DiSEqC Switch 4/1
Position/Option Shaltkriterium Sat
A/A 1 Astra 19,2
B/A 2 Eutelsat 13,0 (hotbird)
A/B 3 Astra 23,5
B/B 4 Astra 28,5
I am running DVBViewer 3.9.
BBC Prime config : Feq 11117 pol V symrate 27500 3/4
I have got pretty much similar CI problem with the same TV card ( TH AD- SP400 (1041+4046)
), when migrated to DVBV 3.9 (fresh installation)
The encrypted channels were scanned just OK, I had even possibility to watch them for very short time at the very beginning.
Then it starts to gambling, OK-black screen-OK..., now it is permanently in black screen (FTA channels are OK).
My computer is running under vista 32, with all fresh drivers installed, and with older versions of DVBV (3.6 and 3.8) I have never noticed such a problem.
So, where to "dig", what to check first?
The other my PC HW details are:
- MB - asus M2A-VM HDMI, integrated VGA ATI x1250 is in use
- CPU - AMD X2 4600+
- RAM - 2x 1GB 800Mhz
I would be interested in getting hold of version 3.6 or 3.8 to see if I have the problem with them as
you say you dont have the problem with those versions. I have checked the members download section
and neither of these versions is there.
Anyone know how if these versions are available, I have a valid DVBViewer 3.9 version
Andy
DVBViewer Pro is only available is the Members Section. Any other way divulging is illegal.
OK, that is nice to know, but... how about real help on the issue?
So is there a way to get version 3.8 or 3.6 added to the down load area ?
Who should I talk to ?
No it is not possible.
Okay so any advise on how to proceed ?
Is there anyway to enable some kind of debug info to see if the data stream is
being sent to the decoder, what the decoder does ? Are there any error logs to check ?
Can I use the transedit facility in any way to check anything ? Will it pass
the data stream onto the decoder ?
I am really new to this stuff so I need a few pointers - please HELP
Are the pleasures of programming ..........
Andy
Hi Andy,
After reading this topic:
http://www.DVBViewer.info/forum/index.php?showtopic=21667 (in my case I have not seen the CAM module sometime)
I have reinstalled BDA Mantis driver (well, I have installed entire DigitalTV 3.3 package on top of my existing drivers http://www.twinhan.com/files/AW/Software/D....3build08a.zip), then,
Totally reinstalled DVBV 3.9 (with cleaning all its garbage left) and..., it finally did help.
