dorijan Posted November 9, 2007 Posted November 9, 2007 OK, here is what I want to do, but cannot: On same computer, I need to have DVBServer started, and 2 DVBViewer started connected as clients to that DVBServer. When I try to do this, I start one, and that one works ok, but if I start another instance of DVBViewer (installed in separate folder) I got error No hardware available! If I turn off the first one, second one works ok! So it is definitly problem with DVBServer... Please Please fix this, I really need this (maybe insane to someone) feature thank you in advance... Quote
Lars_MQ Posted November 9, 2007 Posted November 9, 2007 delete the unicast device in one installation and do a manual hardware detection. This should work. Quote
dorijan Posted November 9, 2007 Author Posted November 9, 2007 delete the unicast device in one installation and do a manual hardware detection. This should work. ok...I will try it.. So I should use multicast? Quote
Moses Posted November 9, 2007 Posted November 9, 2007 no. You should "redetect" the unicast device... problem is this: the two running dvbviewers communicate on how they use the available hardware. Both see the same unicast device, so the first one says: "Don't use it! I use it!". I don't remember how it was done, but this was fixed and with a new detection of the unicast device it should be a different one. So the second DVBViewer will have "another hardware" than the first one and both will work. Quote
dorijan Posted November 10, 2007 Author Posted November 10, 2007 no. You should "redetect" the unicast device... problem is this: the two running dvbviewers communicate on how they use the available hardware. Both see the same unicast device, so the first one says: "Don't use it! I use it!". I don't remember how it was done, but this was fixed and with a new detection of the unicast device it should be a different one. So the second DVBViewer will have "another hardware" than the first one and both will work. weeee it is working Quote
