mlehtola Posted November 16, 2007 Share Posted November 16, 2007 Hi, I have a XP pc that has not been updated since sp2. I have used many versions of DVBV, currently 3.8. Every version has the same problem, they crash when I close DVBV. Error is the basic Microsoft notice, so I don't have a clue what's the problem. I'm quite sure that the problem is non updated XP because my laptop that has up to date XP is also running DVBV versions but without any problem. Any ideas what updates should I install? Quote Link to comment
Lars_MQ Posted November 16, 2007 Share Posted November 16, 2007 please rename the plugin folder in the DVBViewer program folder to plugins1. does it then happen? Quote Link to comment
mlehtola Posted November 18, 2007 Author Share Posted November 18, 2007 Hi, I think it helped a little bit, normal usage and deleting savings don't make it crash anymore when closing it, but when I do something for the database (delete orphans/refresh database) I got crash on exit once (have not tested really that much so far). I'll continue tests and tell you how it goes...upgrading to 3.9 today as well I think. Quote Link to comment
mlehtola Posted November 19, 2007 Author Share Posted November 19, 2007 No luck, in many cases, I just open DVBV and then close it -> crash. Other ideas? Quote Link to comment
Lars_MQ Posted November 19, 2007 Share Posted November 19, 2007 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote Link to comment
mlehtola Posted December 12, 2007 Author Share Posted December 12, 2007 (edited) It did the trick after all, don't know why there were still crashes after renaming and booting for couple days . No crashes since 21.11. Thanks! And fun xmas and new year for everyone here! Edited December 12, 2007 by mlehtola Quote Link to comment
