ianred22 Posted November 20, 2007 Posted November 20, 2007 Any one any thoughts on this and whether we will be able to decode the Channel 4 HD stream in the same way as BBC HD. I found a post saying someone had found the test broadcast on "5707" (12.188 H) Channel 4 HD due to go live December 07 Not sure how to find this via DVBViewer, and hints? Quote
Dadag Posted November 21, 2007 Posted November 21, 2007 (edited) From KingOfSat Channel 4 HD test is on 11798H SID 3875, videoguard crypted Scanned this TP as 11720H and 12363V (SR 29500, FEC 3/4, 8PSK), 3 weeks ago, but found all empty Edited November 21, 2007 by Dadag Quote
Kart Posted November 21, 2007 Posted November 21, 2007 Last night when i checked on 11798 H ,Channel 4 HD was transmitting some KungFu Movie with resolution 1920/1088. I had my S*y Card in the Dragon Cam. Didn't try without ,so i'm not sure if it was crypted or not. Quote
Dadag Posted November 22, 2007 Posted November 22, 2007 Last night when i checked on 11798 H ,Channel 4 HD was transmitting some KungFu Movie with resolution 1920/1088.I had my S*y Card in the Dragon Cam. Didn't try without ,so i'm not sure if it was crypted or not. I dont have S*y card (french here) not cleared last night when tested. Quote
ianred22 Posted November 24, 2007 Author Posted November 24, 2007 I dont have S*y card (french here) not cleared last night when tested. I have tried scanning with Transedit using the Astra/Eurobird 28.2E transponder and these frequencies don't appear. Just for good measure I also scanned Astra 19.0 E Can you tell me what transponder I should be using Thanks Quote
Dadag Posted November 25, 2007 Posted November 25, 2007 (edited) I have tried scanning with Transedit using the Astra/Eurobird 28.2E transponder and these frequencies don't appear. Just for good measure I also scanned Astra 19.0 E Can you tell me what transponder I should be using Thanks For the TP, already answered in my first response : 11798H, SR and FEC same as other for Sky UK. You can add it simply with transedit, but DVBViewer restart is needed. 2 good source for TP infos : www.lyngsat.com for all channels on one satellite or www.kingofsat.com for search by name Edited November 25, 2007 by Dadag Quote
