Recenty Used Channels
Kevin Bishop
When I press the Red button om my MCE remote, it brings up a list of 'Recently Used Chan....' After doing some reserach I realise this list is acually Most Frequently Used Channels. Is is possible to manage this list? - Some of the channels I chose to view late at night apear in this list and I would rather they didn't! ;)
[i thought this post might cause some amusement, but I bet I'm not the only one who benefits from the answer!]
Edited by Kevin Bishop
Have a look into the actions.ini. You can define a inputaction which deletes this list on keypress in the inputoptions. Just define a custom command.
The action is called:
Clear Channel usage counter
Thanks - I have found the line, it is currently set to 8255, what do I set it to?
nothing. in the options -> inputoption add a custom inoput command and choose this action. The assign a key to it .
Ok have have doen that, but when I press the key, the list remains unchanged - do I need to restart DVBViewer?
Sorry Kevin, but giving it a go would take a shorter time than asking / as an expert of IT.
Edited by ricabullah
I hear what you say, and I appreciate how frustrating it is, but I had several hours of recordings in progress and only a breif oportunity to work on this system. I was trying to asses whether it was worth my continuing or waiting for the next time I can work on this in several days time.
I will try a restart at the weekend, and see if that fixes it.
I have now restarted DVBViewer (several times) and this setting has made no difference.
I now see the option to 'Clear Channel Usage Counter' in the Inputs section, I have assigned the backspace key, but when I press it nothing happens. I have tried other keys - same result.
