tjabbaranx Posted December 11, 2007 Posted December 11, 2007 Like the headline says, A guide how to get egp in DVBViewer work, or have i missed something?? I do not get epg to my channels. I have the newest version. Do i have to use use some grabber or what? I use floppydtv -c with Xp. I have tried O2grabber and some other programs but i seem not to get it right. Plz someone help me! Quote
Lars_MQ Posted December 11, 2007 Posted December 11, 2007 tried to simply tune the channels? EPG is automatically received. Quote
tjabbaranx Posted December 13, 2007 Author Posted December 13, 2007 tried to simply tune the channels? EPG is automatically received. Yes, but nothing happens. I tried reinstall a couple of times. But nothing. Is DVBViewer set to recive epg automaticly at default after the installation? Quote
Lars_MQ Posted December 13, 2007 Posted December 13, 2007 ofcourse. Other way round: which channels are you speaking of, which receptiontype, which DVBViewer version. Quote
Benarty Posted December 13, 2007 Posted December 13, 2007 ofcourse. Other way round: which channels are you speaking of, which receptiontype, which DVBViewer version. Or: In the epg options, add the transponder frequency and the polarisation (H/V) of the channels . Choose mediahighway 1 , if that fails, mediahighway2 and at last Siefern. I too received no epg info but after this step, yes, epg info. Quote
tjabbaranx Posted December 13, 2007 Author Posted December 13, 2007 ofcourse. Other way round: which channels are you speaking of, which receptiontype, which DVBViewer version. I have cabel, a floppydtv-c, with DVBViewer 3.9.1. I live in Sweden so therefor swedeish channels... I have tried like Benarty suggested but still nothing. Quote
Lars_MQ Posted December 13, 2007 Posted December 13, 2007 Please post the support.zip, so we can see if there are problems with your settings: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
misterju Posted December 13, 2007 Posted December 13, 2007 im also having the same problem, i installed 3.91 into the same directory of 3.9 to remain the channel list and settings. Quote
tjabbaranx Posted December 13, 2007 Author Posted December 13, 2007 Please post the support.zip, so we can see if there are problems with your settings: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Ok i will do that! support.zip Quote
Lars_MQ Posted December 13, 2007 Posted December 13, 2007 the settings seem to be ok. Are you sure your dvb provider provides EPG? Quote
misterju Posted December 14, 2007 Posted December 14, 2007 Hello i fixed the problems i had (thanks to admin ) , but i still have problems with epg, i ve tryed different settings on epg options, and still not receiving form any programs, i ve tryed ZDF, prosieben hd and more channels of astra, i ve attached the support file in order to check it, things ive done: receive data with epg mediahighway, checked and unckecked change timings of epg info ... no results hope any answer apreciate .. thanks ! support.zip Quote
tjabbaranx Posted December 14, 2007 Author Posted December 14, 2007 the settings seem to be ok. Are you sure your dvb provider provides EPG? I have talked to them and they said that there should be. Anyway, i will go back to try import tv channels again. Without a epg the whole idea falls... Quote
Tjod Posted December 14, 2007 Posted December 14, 2007 @misterju if you "Disable EPG receiving" (Options > Hardware) you will gen on EPG. Enable it and it should work. Quote
tjabbaranx Posted December 16, 2007 Author Posted December 16, 2007 I have talked to them and they said that there should be. Anyway, i will go back to try import tv channels again. Without a epg the whole idea falls... Wohoo! I just got EPG to work I used Auto Import XMLTV from the Plugins & MODs section! I still do not get epg from my provider, but i dont care (hmm I`ll bet they dont send out...). This is just as great! Now i can go out and explore the rest of this excellent program. I feel like i am really close to the perfect HTPC whit DVBViewer! Thanx anyway for all the help! Quote
