themaster1 Posted December 13, 2007 Posted December 13, 2007 (edited) I'm a new adept of DVBViewer feels good to be part of the family I've got a little issue regarding the way DVBViewer let me zap through the channels list (ideally the "favorites" but it won't) Previously I used dvbDream (freeware) which has 3 categories: general/favorites/tv remote When I'm in one of those categories I can zap according to what's on the list and that's what I wanna do/expect with DVBViewer, am I clear? Example: Currently when I zap, (despite I have assigned numbers to channels in the favorites list ) it seems to refer to the channel list (not the favs) I don't wanna delete channels in the channel list just because of a zapping problem . So you may ask what do I get as a result? Well the answer is simple: When I type 2 on my tv remote instead of getting let's say MTV channel I get another channel to resume i just wana be able to zap the channels according to my favorites list & i don't know how to do that I'm a newbie, aight, be nice with me themaster1 Edited December 13, 2007 by themaster1 Quote
Gioxy Posted December 14, 2007 Posted December 14, 2007 I guess you can find the "How to" in this post: Open Favorites list as Channel list Quote
Tjod Posted December 14, 2007 Posted December 14, 2007 You have to Learn the Numberkey (Option > Input) to Favorite 1, Favorite 2 .... Quote
themaster1 Posted December 14, 2007 Author Posted December 14, 2007 Ah i get it now first I gotta use the filter in the channel list to only "let" the fav chans (so filter= is favorite) appear and also disable the options for sorting the channels names/numbers Once this is done in the input panel I gotta change the combo keys for the favorites and it works like a charm. Thanks ! Quote
themaster1 Posted December 14, 2007 Author Posted December 14, 2007 I've got another little trouble regarding the tv remote and subtitles/audio track. How can i change the audio track for a given channel and how could i choose the subtitles (put them on/off) for a file i play. I don't see inputs for that Quote
Tjod Posted December 14, 2007 Posted December 14, 2007 Try OSD-Blue. Or you add new Inputcommand (Option > Input) Add Group > select the new Group > Add > enter a name > select a command from the drop down menu > Add > OK Quote
themaster1 Posted December 14, 2007 Author Posted December 14, 2007 Try OSD-Blue. Or you add new Inputcommand (Option > Input) Add Group > select the new Group > Add > enter a name > select a command from the drop down menu > Add > OK Thanks Tjod looks like it work now, this software is awesome! Quote
