antdude Posted December 28, 2007 Author Posted December 28, 2007 (edited) OK, I finally found a tool to extract CCs/subtitles to SRT text files from both of my MPEG2 and TS recording files. However, they took a long time. Also, how come DVBViewer doesn't show CC/subtitles for MPEG-2 files? The tool showed CC/subtitle inside my MPG files. Edited December 28, 2007 by antdude Quote
hackbart Posted December 28, 2007 Posted December 28, 2007 We do support closed captions inside mpg files. You have to enable the checkbox in the DirectX Options to "Use DVB Source for Mpeg Playback". Quote
antdude Posted December 28, 2007 Author Posted December 28, 2007 (edited) We do support closed captions inside mpg files. You have to enable the checkbox in the DirectX Options to "Use DVB Source for Mpeg Playback".I already had that box checked, but no luck. I uploaded a screen shot: http://img293.imageshack.us/img293/5705/screenshotra7.gif ... TS files had no problems. Edited December 28, 2007 by antdude Quote
antdude Posted December 30, 2007 Author Posted December 30, 2007 FYI. Playing subtitles/CCs from MPEG and TS files that have SRT files (same filenames show up on my TV in the latest K-Lite Codec Media Player (doesn't play CC/subtitles from in those files though which is a known issue). DVBViewer can't for TS files on my TV regardless if I use the ones in their files or their SRT files. Quote
antdude Posted January 1, 2008 Author Posted January 1, 2008 Happy New Year! Does setting font color (not the shadow and outline since I set them to zero) not work for subtitles/closed caption? I told DVBViewer Pro to use yellow, but I don't get yellow. I still get white. Quote
antdude Posted January 13, 2008 Author Posted January 13, 2008 Hi. I noticed when some scenes have no subtitles/CCs so the last subtitles/CC stay on my screen stuck until the next update (new ones). Quote
antdude Posted January 18, 2008 Author Posted January 18, 2008 So I upgraded to v3.9.2.0 and still see some problems that I noted like missing subitltles/CC on TV, don't see the specified font color I picked, etc. Quote
