geir Posted September 25, 2003 Posted September 25, 2003 Hi there I am having problem with tv out on my computer. I have geforce 5200 adapter and I am trying to watch the DVBViewer in my tv with the TV-OUT connector. but even though I can see the picture in my computer and I can see my computer desktop in my TV there is everything black inside the DVBViewer in my TV:-( Hope that some can help me. thank you Geir. Quote
Nogger24 Posted September 25, 2003 Posted September 25, 2003 Hi there I am having problem with tv out on my computer. I have geforce 5200 adapter and I am trying to watch the DVBViewer in my tv with the TV-OUT connector. but even though I can see the picture in my computer and I can see my computer desktop in my TV there is everything black inside the DVBViewer in my TV:-( Hope that some can help me. thank you Geir. I have a similar problem with WinDVD...only in FullSreen I can watch DVD from my notebook on TV! Have a try! Quote
Griga Posted September 25, 2003 Posted September 25, 2003 A solution for NVidia cards is desribed in the last posting of this thread - unfortunately only in German, and I have no time to translate it now. May be you can get it via Babelfish Translation Service, or someone else can translate the important part... Griga Quote
Guest DAvenger Posted September 25, 2003 Posted September 25, 2003 You must simply disable your PC's monitor output so only tv out is active ... see Display Properties/NVIDIA in Windows Quote
Griga Posted September 25, 2003 Posted September 25, 2003 Well... rather the Overlay Output via TV Out must be enabled - that's how I did it. Usually there is a tab for Overlay in the GeForce Display Properties with a dropdown list (titled "Full Screen" or so). The "Secondary Display Device" must be selected there. After that, the DVBViewer's Output in Overlay Mode is automatically displayed as full screen on the TV - even when the DVBViewer is minimized in the taskbar. That means, you'll see the desktop on your monitor, and the TV picture on your TV then. It may depend on the graphics card, however... it works as described with my GeForce MX 440. If you can't find a Overlay Tab in the NVidia Display Properties, try to update the graphics card drivers. Griga Quote
