riviera Posted January 14, 2008 Posted January 14, 2008 Hi. It's possible to start DVBViewer in a second monitor (extended mode) and full screen by default? Thanks Quote
riviera Posted January 15, 2008 Author Posted January 15, 2008 Nobody watch DVBViewer in a tv panel connect to htpc by hdmi/dvi connection? Many htpc/dvb player softs includes this option. Could be possible implements it by script? Thanks Quote
mr_chaela Posted January 15, 2008 Posted January 15, 2008 (edited) Nobody watch DVBViewer in a tv panel connect to htpc by hdmi/dvi connection? Many htpc/dvb player softs includes this option. Could be possible implements it by script? Thanks If you drag DVBViewer onto the second screen, then close it, it will remember where to start next time you run it. Alternatively, use launcher.exe to specify the top left position of the viewer on your extended desktop http://www.DVBViewer.com/hartwig/launcher.zip I use 2 instances of launcher (launcher.exe and launcher2.exe - just rename it) to start the viewer either on my pc or on the tv panel. I actually use starter.exe - see members area - to call launcher2 so that I can start the viewer on the tv panel with the remote, hth Edited January 15, 2008 by mr_chaela Quote
Tjod Posted January 15, 2008 Posted January 15, 2008 For Full Screen use Options > General -> Start in Full Screen Mode. Quote
dgdg Posted January 15, 2008 Posted January 15, 2008 (edited) Aber war das nicht so, dass sich der DVBViewer gerade im Fullscreen-Modus NICHT seine Position (also den letzten Bildschirm) merkt. Oder betraf das nur die Aufnahme-Programmierung- und EPG-Fenster ? Das kann man sich als Anwender schwer merken, weil sich jedes Fenster so verhält, wie der Programmierer bei der Implementierung gerade drauf war - eine einheitliche Regel gibt es nicht. Für den Benutzer entsteht durch die Inkonsistenzen der Eindruck, dass das gar nicht oder nicht zuverlässig funktioniert. Edited January 15, 2008 by dgdg Quote
Tjod Posted January 15, 2008 Posted January 15, 2008 @dgdg In the English part from the board no German. But no need to translate this everything you have written here is nonsense. Quote
dgdg Posted January 15, 2008 Posted January 15, 2008 (edited) So DVBViewer remembers fullscreen mode for the recording and EPG window on your system ? Edited January 15, 2008 by dgdg Quote
riviera Posted January 16, 2008 Author Posted January 16, 2008 If you drag DVBViewer onto the second screen, then close it, it will remember where to start next time you run it. Alternatively, use launcher.exe to specify the top left position of the viewer on your extended desktop http://www.DVBViewer.com/hartwig/launcher.zip I use 2 instances of launcher (launcher.exe and launcher2.exe - just rename it) to start the viewer either on my pc or on the tv panel. I actually use starter.exe - see members area - to call launcher2 so that I can start the viewer on the tv panel with the remote, hth Thanks for the answer. This is what we were looking for Quote
