modify Button association on Windows MCE remote
ardua97
when use the remote and I press some button
like that with the flag (run Windows media center ) or the Guide button or the registration button
they start Windows media center applications
I wanted to know if it is possible to associate the button only to DVBViewer
If you don't use your Windows media center, you can disable "ehtray*" from start up options. I do not know, if you can assign the keys only to DVBV if ehtray is active.
thank you very much for the answer
I tryed to disable "ehtray*"
I execute msconfig , then i'm gone in Startup setting and I renmoved flag to ehtray
then i Have restarted the computer
but when i push the guide button or the start button
the computer lounch windows media center
I have windows vista home premiun as SO
I also had the same problem, and i found out how to solve it.
All you need to do is to rename the "ehome" folder so something else like "ehomeold" and it should work ;)
