ponch.82 Posted January 15, 2008 Posted January 15, 2008 (edited) Hi, i'm new in this forum, so thank in advance for any help.. so let's begin describe what i found: i bought a week ago the new Technisat Skystar HD 2 (dvb-s2), installed correctly whit bda driver (bda mantis), and installed the new version of DVBViewer (3.9.1). i got a 120cm dish, with Satracer3 rotor, for large dishes, and a quad lnb with 4 different connector. Befor this card, i always used the "old" SS2 2.6D revision, with correct bda drivers and the mibi plugin for diseqc (alway worked well). i read all over this forum trying to find out how to set correctly the diseqc 1.2 command, usals and so on. i set up a list with 3 satellites only, hotbird 13E and astra 19.2E, and i insert the diseqc 1.2 command string raw from the program diseqc.exe (for now i prefer to use command string even if the usals are working too for this two satellites). the rotor i driven correctly manually, from the positioner menu in DVBViewer, drive est, ovest, with steps and witout (going to E/W limit). in the channell list i sep up the command string enclosed by [], and everythings is correct. the problem begin when i try to change from a channel in Hotbird 13E to a channel in Astra 19.2E... the rotor still in the same position After an our on my roof, cheking connectors, lnbs, drivers, program ecc, i found this: going in the positioner menu and only selecting the driver (bda mantis), closing the menu and return in the channel list, if i change channel the rotor moves! So, every time i want to change satellites, i have to go in the positioner menu and select the driver... than i can change channel and see the rotor moving automatically switching the satellite. Don't know if the problem i described clearly, hoping this will be fixed in new version. All other thing are wonking great, only one thing: would be possible to implement a better menu for the diseqc 1.2 for rotor? something like giving directly raw command and gotoXY command in degree, for example. In this days, i think i will setup western satellites (think to hispasat), and i will try to move with usals and raw commands, to see if everythings is ok. support.zip Edited January 15, 2008 by ponch.82 Quote
Angel Angelescu Posted March 24, 2008 Posted March 24, 2008 (edited) I made the same install but with the original driver from Technisat cd and USALS works only manual (go east/west) but not following channels. With Hauppauge HVR-4000 everything works great. How to get some drivers to make SkyStar HD2 to use USALS too? Edited March 24, 2008 by Angel Angelescu Quote
drughi77 Posted May 14, 2008 Posted May 14, 2008 I made the same install but with the original driver from Technisat cd and USALS works only manual (go east/west) but not following channels. With Hauppauge HVR-4000 everything works great. How to get some drivers to make SkyStar HD2 to use USALS too? did you manage to use the Skystar HD 2 with a dish on rotor. I have got the same setup but don't have an idea of what to do. I didn't know that the skystar hd2 does not support the rotor (Usals) and i was going to sell it immediately until i found this forum. pleasecan somebody help me. Thanks Quote
