ftsa Posted October 4, 2003 Posted October 4, 2003 Hi, I have a DXR3 card, wich because of the lousy drivers for WinXp, i installed it as a Hollywood Plus, since they seem the very same board. I am using it with Skystar 2 to do the MPEG decoding using a graph in graphedit. I use a DVBCore -> H+ directshow filter -> Line 21 decoder -> Color Space converter -> Video Renderer I tried multiple configs but the main problem prevails : The Video is not smooth at all and has lots of random delay when compared to the Audio wich runs very good. Can i use another filter instead of the H+ directshow filter ? Someone talked about a rmmpeg2.ax file but i cant find it anywhere. Can somebody give a hint here ? Tx Filipe SA Quote
Guest Oliver Posted October 4, 2003 Posted October 4, 2003 I use a DVBCore -> H+ directshow filter -> Line 21 decoder -> Color Space converter -> Video Renderer Are you sure about that? The DVBViewer doesn't use DVBCore. And you shouldn't need the color space converter. Bye, Oliver Quote
ftsa Posted October 5, 2003 Author Posted October 5, 2003 This graph is for MyTheatre. I didnt build a graph for DVBViewer yet, as i dont quite know how to work with it. Anyway what i am looking is a replacement for the H+ filter, but one that uses the hardware decoding ability of the card of course. Yes , i dont need the color space converter. But the prob presists. Tx filipe Quote
Guest hackbart Posted October 5, 2003 Posted October 5, 2003 Building a graph for the DVBViewer almost that simple (maybe even more) In theory you do not need to build your own graphfile, just enter under options the GUID for your H+ codec (if the one i added months ago does not fit).. Christian Quote
ftsa Posted October 6, 2003 Author Posted October 6, 2003 My status is this now : I have tried in multiple programs a H+ filter that worked on Mytheatre almost perfctly. It was not perfect because the sound was delayed for about 1-3 seconds and sometimes more. I think the filter was bad so i found the rmmpeg2.ax filter. I registered it and went to Graphedit to build my graph. It appears this when i try to choose it : "This filter could not be created. Resources used by this filter may already be in use. Ran ou of memory ( Ref code 0x8007000e)" What can i do ? I unregistered the previous filter but the error keeps the same. I hope someone helps here, tx filipe Quote
